Question about GE JASRM24912 Remote Control
Codes I need info on programming and the 3 digit codes for a Sanyo TV and a Zenith VCR
  • 689 Answers
Posted on Jan 09, 2008
I need all the remote codes for a synergy5 remote so that i can control my zenith t.v.
Hi
Setup code for Synergy-5 remote control with Zenith TV are:
047 048 049 050 051
391 405 406 434
Proceedings.
[1] Turn on all the electronic devices (TV, VCR, DVD, AUDIO) you want to program the remote to operate
[2] Press [OK], then [MUTE] together until the power / mode buttons illuminate in slow-rotation (i.e. CBL ?
TV ? VCR ? DVD? AUDIO ? CBL...).
[3] (a) To program your TV, locate the 3-digit code for your brand in the TV Setup Code list and enter it on the
keypad of the remote control. Entry of the correct code will cause your TV to turn off. If multiple codes
are listed for your brand, you may have to try several different codes until your TV turns off.
(b) As soon as you have entered a 3-digit code that turns your TV off, press [MUTE].
(1) If the TV turns back on, press [OK] to lock in the code. The power / mode buttons will blink 3-
times and go out.
Or
(2) If the TV does not turn back on, enter a different 3-digit setup code until your TV turns back on.
Then press [OK] to lock in the code. The power / mode buttons will blink 3-times and go out.
OK.
Jul 23, 2011 | Zenith Televison & Video
I recently purchased a "TDE SYSTEMS" jumbo
sanyo tv codes are 0506,0311,0612,0002,0428,0802,0412,0619 and emerson vcr are0626,0126,0826,0227,0327,0630,0632,0134,0037,0625,0924,0324,0128,0228,0428,0528,0447,0247,0724,0325,0526,0726,0027,0527,0827,0927,0628,0530,0830,0731,0634,0735
Dec 13, 2010 | Televison & Video
TV/VCR no setup key. Where is the setup key? Remote
how do i put TV codes in my SANYO remote it has the number IR 5435 on it dont no if thats the model or not
Feb 13, 2010 | Televison & Video
Programming a sanyo tv with rcu403a remote and
Hello Jeffro
Programming a device using the Code Lists:
1- Sanyo 017,021,039,056,057,058 (codes)
2- Press and "HOLD" CODE SEARCH.
3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH.
6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists
Hope this helps you out.
Cheers Little Dish Fitter
Oct 09, 2009 | RCA RCU403 Remote Control
Need codes for zenith tv
www.rockabilly.net/files/manuals/URC-3220.pdf
Jun 04, 2009 | One For All URC4220 Remote Control
Need code for zenith on urc-3220
016,017,092,000,[COMBO--000,037] are the codes
for your Zenith TV. Follow these instructions
carefully. These are as close as i can get you
to getting you operations...the rest is up to
you. GOOD LUCK!
  1. PRESS the button for the device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER the 3 digit code for your brand.
  4. You should receive 2 quick flashes after entering your code.
  5. PRESS the POWER button to test the code.
If you have tried all of the set-up codes for your brand of equipment, or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
  1. PRESS the button for device you want to program,(TV,VCR,CABLE,etc.), then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE(TV,VCR,CABLE,etc.) button until your device turns off.(On VCR,LD,and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
Blinking Back the Code:
  1. PRESS the device,(TV,VCR,CABLE,etc.), button - RELEASE
  3. PRESS 9 - 9 - 0.
  4. PRESS 1, carefully COUNT the number of blinks. (1st digit)
  5. PRESS 2, carefully COUNT the number of blinks. (2nd digit)
  6. PRESS 3, carefully COUNT the number of blinks. (3rd digit)
If the remote DOES NOT blink it means the number is 0.
This is your 3-digit setup code.
Mar 03, 2009 | RCA Universal Remote Control
Codes for universal remote
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
Jun 25, 2008 | RCA Universal Remote Control
Need a code for my tv zenith
Zenith Product Codes
TV Mode Zenith Code 101 - VCR Mode Zenith Code 201 - Cable
Mode Zenith Code 353 - AUX Mode Zenith Code 401.
Programming Codes---
TV - 101 149 175
Apr 27, 2008 | Zenith B27A11Z 27" TV
Sitting in a cheap hotel room after work and have to get up to change the channel, have a Philips universal cl034 remote but do not know how to program it to the older Hitachi tv.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
Here is the link for your remote.
Here is the list.........
Save Code list for future reference Refer to the setup procedure below and look up the 3 digit code for your brand of TV, VCR, etc., from the list below.
Refer to the Owner’s Manual for your remote for more information.
TV including LCD,
Plasma, & Panel TVs
HITACHI ........... 0410 0507 0815 0607
....... 0808 0002 0502 0710 0701 0802
....... 0707 0315 0515 0715 0519 0324
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
3. Press and release the desired Mode
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing “0” performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
controlled changes channel.
6. Press and release MUTE to install
the code.
Note, when all codes under a Brand
have been searched the red indicator
flashes rapidly for 3 seconds.
Code Search (by Device)
If after trying “Direct Code Entry” or
“Code Search (by Brand)” your device
does not respond, or if your brand is not
listed, try doing a device search of the
code library for your code by following
the steps below.
1. Manually turn on the device (TV,
VCR, etc.) to be controlled.
button.
4. Press the CHANNEL UP button
repeatedly (up to 300 times) until
the device to be controlled changes
channel. The red indicator blinks,
then stays lit.
5. Press and release MUTE to install
the code.
Most users will want to store VCR
codes under the VCR button, Cable
codes under Cable, etc. If you want to
store a VCR code under Cable, etc., first
follow the procedure for Direct Code
Entry and press Cable in step 2 of
Direct Code Entry, then enter ANY
VCR code in step 3 of Direct Code
Entry. Then follow the steps above for
Brand Search or Complete Search.
Brand Search Table
Look up your brand in the appropriate
column (TV, VCR, etc.) in the table
below. Look for the digit (1, 2, 3, etc.)
that applies to your brand, and enter it
in step 4 of “Code Search (by Brand).”
Digit
6
78
90
TV
RCA, GE,
Proscan
Zenith
Philips,
Magnavox
Sony, Panasonic,
Sharp, Toshiba,
Daewoo
Hitachi, Sanyo,
LG-Goldstar,
Samsung, JVC,
Mitsubishi
Sylvania, Fisher,
Curtis-Mathes,
Emerson
N/A
N/A
N/A
ALL
VCR/DVD/DVR
RCA, GE,
Proscan
Zenith, Apex
Marantz, Philips,
Magnavox
Sony, Panasonic,
Sharp, Toshiba,
Daewoo, Yamaha,
Denon
Hitachi, Sanyo,
LG-Goldstar,
Samsung, JVC,
Mitsubishi
Sylvania, Fisher,
Curtis-Mathes,
Emerson
N/A
N/A
N/A
ALL
CABLE
Scientific Atlanta
Jerrold
Tocom, General
Instrument,
RCA, GE,
Proscan, Pioneer
Zenith, Gemini
Philips,
Magnavox
N/A
N/A
N/A
ALL
SAT/DBS
RCA, GE,
Proscan, Pioneer
Zenith, Gemini
Philips,
Magnavox
Sony, Panasonic,
Sharp, Toshiba,
Hitachi, JVC,
Samsung
General Instrument,
Echostar, Dish,
Hughes, Primestar
N/A
N/A
N/A
ALL
CD/AUDIO
RCA, GE, Proscan
Zenith
Marantz, Philips,
Magnavox
Sony, Panasonic,
Technics, Sharp,
Toshiba
Hitachi, Sanyo,
JVC, LG-Goldstar,
Samsung,
Mitsubishi
Sylvania, Fisher,
Curtis-Mathes,
Emerson, Optimus
Pioneer, Teac, Nad
Kenwood, Yamaha,
Denon, Onkyo
N/A
ALL
HDTV Set Top Boxes
HITACHI . 0538 0324 0336 0931 0834
Mar 04, 2008 | Televison & Video
GE JASRM24912 Remote Control Logo
178 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
