Most ovens with self-clean cycles have a door lock to keep things closed when it ramps up the the extreme heat levels for cleaning. Usually, the door will stay locked until the thermostat sensor says that the oven is back down at or close to room temperature. If you just finished the cleaning cycle, you'll likely need to wait a while longer.
The upper element is for broiling and should not come on until you tell it broil. If it is coming on as soon as you turn on the breaker then it sounds like the printed circuit control board is bad. There is a relay on the board that engages when you program in the broiler. The relay can be hard to find and may not be removable. My broiler would come on when I programmed in the bake mode, go into runaway heat, put up a F10 code, and shut off. I could not clear it until I programmed in the clean mode for 2 hours. Now it works great.
This usually is caused by a bad convection fan motor. This is something that you should have a technician replace, but ask for a price quote first. Fairly expensive to fix and usually very complicated to get at. Good Luck, Appliance Specialists
Here is what you do when the convection oven door locks automatically. Where the stop/clear button is, you will see a lock symbol that has a number 3 on it. hold the stop/clear button down for 5 seconds and it will unlock you convection oven.
does the bake element come on at all? if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off. on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
