Question about RCA P61927 61" Rear Projection Television
RCA P61927 NO POWER!!! HELP
My TV last week kept shutting off and back on by itself occasionally for about a week. Yesterday it will not turn on at all it just makes a ticking noise inside like a watch. I did open the back and noticed a lot of dust so I cleaned it and checked for lose plugs nothing looked lose or burnt back there and checked the little fuse also was good. Does anyone know what happened? Is it woth repairing it. Thanks ADAM
  • 373 Answers
If it is a ctc or ptk 195 then you have a bad flyback High Voltage transformer: the large white kindof square thing with big red wire coming out; Must get original RCA part. If picture was good before could cost you a total of (average) $300.00 according to which repairman.
Posted on Dec 29, 2007
The TV started turning itself off occasionally a
Most likley what it could be is an interferance in the TV. Modern TV's have a feature that will shut itself off when it is not receving a picture. For instance, after so many minutes of "snow" it will shut off.sometimes this can make the TV think there is no signal at shut itself off.Anyway, I suspect its an interferance issue. Perhaps moving the TV further from the source of the interferance might help.
Sep 17, 2009 | Televison & Video
RCA 2001 P61927
Okay there is something wroung with the frount panel there may be debris in where the button is depressed or seomthing is depressing the button or it may be just going out on you.
1. take off the frount cover and examine the channel up and down make sure its clean and there are no debris.
2. if that does not work replace the controller board aroun $65 bucks.
I do not know your zip code but you can give these folks a shot www.teexp.com you can call and ask how much it would cost to replace this controller even though they might not work in your area they still can give you a price.
Thanks
Jul 17, 2009 | RCA P61927 61" Rear Projection Television
The power button on my tv pushed in
The board is fine, unless u cracked it. You need to change the buttons only. Shouldn't be hard to find. Look for RCA microswitches.
Apr 08, 2009 | RCA P61927 61" Rear Projection Television
Turned on the tv, heard sizzling sound and it immediately shut itself off. Won't turn on now. It had been turning itself off periodically now and then for the last couple of weeks with no noise and then...
sounds like dust collected on the internal parts which after enough time can cause it to stop working. either have tv repair specialists replace the mother board, or replace tv
Oct 28, 2017 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv turning off by itself occasionally
Just had mine repaired yesterday.
They relaced a TD4611 voltage regulator and a C2200uf 50v part.
Total including service call $188.00 in Western Canada.
Phil
Jul 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch rear projection kept shutting off
bad flyback you can get a new one at the following link for about 50.00 they include free instructions and free tech support with every purchase so you can do the repair yourself. You need Flyback 259296 RCA Heres the link
http://servicemanuals.vstore.ca/
May 02, 2008 | RCA D52W19 52" Rear Projection Television
RCA P61929 picture problem...
The TV was working fine, some time during the night the power went out, its plugged into a surge protector, everything else works fine, the TV won't turn on, the fuse is fine, is there a reset switch?
Dec 06, 2007 | RCA P61927 61" Rear Projection Television
RCA P61927 61 in Rear Projection Television
Hello, Replace U14501. (Maybe) Best regards, Arpi
Apr 22, 2007 | RCA P61927 61" Rear Projection Television
Powers off by itself
Usually leaky power supply diode and two bad caps-----need service # and chassis # from sticker on back of set .....T.
Jan 22, 2007 | RCA 32V420T 32" TV
RCA P61927 61" Rear Projection Television Logo
119 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
