Question about Symphonic SC309D 9 in. TV/VCR Combo
Powers off on its own/ will not load VCR tape
I have a symphonic SC309B it powers on ,but shuts off after 6 sec.
It will not load VCR tape
Please email me at roadsport1@comcast.net
  • 2 more comments
  • bb12 Dec 18, 2007
    i turn it on and it shuts off after about 5 or 6 seconds
  • Anonymous Sep 05, 2008
    vcr tape won't insert and tv combo keeps shutting of after a few seconds
  • Anonymous Nov 29, 2008
    I am having the same problem when loading tape to VCR it plays and after a few seconds it shuts the tv off. The television plays just fine. what it the problem with the VCR? Please help.
  • hilliard_jer
    hilliard_jer Sep 14, 2012
    Mine is doing this too! I really need this thing to work guys.
I'm having the same problem. please let me know if you've found a solution.
Posted on Dec 18, 2007
Tv/vcr shuts down after 5 secs.
There is likely an issue in either the primary or the secondary power supply that is causing the TV to shut down. Unless you or someone you know is good at repairing switching power supplies, there's not much you can do to save this unit.
Oct 07, 2016 | Symphonic SC-3813 13-Inch TV/VCR Combo
My vcr plays or records for 12 sec and shuts off then when i cut on the power it ejects the tape....also when i power the vcr with no tape a wheel is spinning in the back right corner whats wrong?
This can be due to many faults and need a full check up but I can fill up with few tips.
1. If the cassette loads and the take up spool does not turn then the machine will shut and rewind.
2. If the take up spool rotates but then it shuts down then the reel sensor at the bottom of the forward wheel can be faulty- there are opto devices or proximity sensors/magnetic type.
3. If the drum does not rotate it will shut down as well a fault in the SERVO section.
4. Defective HALL IC can shut the switching and so the servo will shut down the processor.
5. Fault in the power section to deliver the correct voltage to the circuits/loading servo to take up.
6. Finally if the loading is not to the MODE switch point or failure of mode can make the loading to trip as it will not complete the load to the desired point.
Sep 27, 2011 | Cameras
My grandson was watching an old VHS tape and pushed something. Now, all I see when I turn the t.v. on is "counter00.00" and then the t.v. shuts off in about 3 seconds. I have lost the owners manual. HELP!
Left up the VCR tape gate,see,if the tape still in there?Yes,unplug,10 mins.replug the Tv and push the tape forward botton.Let the tape go forward about 5 sec. eject the tape take out.Grandson probally rewind the same seen to many times,causing power power shotdown mode.
Aug 09, 2010 | Symphonic SC3813 13 in. TV/VCR Combo
A tape was stuck, As I tried to get it out the
I geuss the timing of the deck is off.Realignment wil be needed.
Aug 01, 2009 | Symphonic SL260A S-VHS VCR
Tape wont eject
Veri8fy that the belt on the side of the VCR mechanism is intact. If it is, then check that the motor works, by appying 12 volts to it,with the belt disconnected. If the motor works, it might be that your mode switch needs cleaning, and that takes some fancy unsoldering and soldering.
Sep 06, 2008 | Symphonic WF-719 19 in. TV/VCR/DVD Combo
VCR stops, ejects, eats tapes
clean the heads and retime the gears.
Nov 24, 2007 | Symphonic WF802
Tv vcr combo
The best way I can think of is to REMOVE the rubber band that loads the tape into the transport unit.Be KILLFULL (careful) the band is right next to the B+ (power supply) or the A\C 120volt
( and if u can find the replacement rubber bands, buy 2 kits)
Nov 16, 2007 | Symphonic SC319C 19 in. TV/VCR Combo
Symphonic SC309D 9 in. TV/VCR Combo Logo
291 people viewed this question
Top Symphonic Televison & Video Experts
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
