Question about M-Audio MicroTrack 24/96
Won't record When I press the red "record" button, instantly a message comes up that says "Writing file!" and the unit freezes.
  • Lisa Loving
    Lisa Loving Jan 02, 2008
    This didn't work. And I'm definately not pressing the record button twice. It's clearly a software problem -- could it be from trying to update the software using my Mac computer, rather than a PC, which is what I've always used with this model of recorder before? Or possibly some screwup in updating the software -- it started after the last time I updated the software.
    Maybe if I just go out and find an available PC and try reloading the software update, that will solve it?
  • 319 Answers
You may need to reset your Firmware to the original.
Here are DETAILED instructions from M-Audio:
Instructions for restoring MicroTrack II firmware version 1.0.0:
If you have attempted to update your MicroTrack II with original version MicroTrack I (MicroTrack 24/96) firmware and now your MicroTrack II is not functioning, please verify the following steps:
Power the unit on, observe that the LCD says “M-Audio Booting Firmware”, and then random characters are displayed (sometimes “Max time per file:” or a “+” sign). The unit then fails to operate properly.
If the above description matches your situation, please follow these steps:
Installation Instructions:
1. With the MicroTrack II powered off and disconnected from the computer/power adapter, insert a Compact Flash card into the device.
2. With the unit in the off-state, plug it into a computer.
3. The unit should power into USB mode and will show up as a mass storage device/removable disk.
4. Within the OS reformat the card. For instructions on how to do this, please see the “Formatting the Compact Flash Card” section below.
5. Copy all of the files included in the zip/DMG file, except the Readme instructions, to the root (top) directory of the inserted compact flash card (Do not put them inside of a folder).
6. Properly unmount the compact flash card from the computer (Please refer to your MicroTrack II User Guide for detailed instructions) and then disconnect the USB cable from the MicroTrack.
7. Power off the MicroTrack II.
8. Press and hold the Menu button.
9. With the Menu button held down, press and hold the Power button. When "Booting Rescue Disk" appears on the MicroTrack II's screen, release both buttons.
10. The MicroTrack II will now display the Firmware Update screen, reconnect the USB cable to the MicroTrack (the other end should still be plugged into your computer).
11. Press the NAV switch to update the firmware.
The MicroTrack II will show several status messages on the screen while the update is in progress. As each of the three stages of the update is completed you should receive a confirmation message that the stage has completed. First, a Bootloader update complete message, then an application update complete message and finally a resource update complete message. As the update is progressing, the four LEDs around the level controls will also flash sequentially. When all three stages of the firmware update are complete, the MicroTrack II will automatically shut down.
To verify the firmware update was successfully installed, power the device on and go to Main Menu > System > Version and press the NAV wheel. After the firmware update, it should now show the firmware version 1.0.0, resrouce file 1.0.0, and bootloader 1.0.
Note about formatting CF Card: Formatting will erase all files on your media card, be sure to copy any important files to your computer before formatting.
1. Connect the MicroTrack II to a USB port on your PC - it will power up in USB mode and will be recognized as a Removable Disk (if the MicroTrack was already powered on, select System->Connect to PC).
2.Open My Computer and locate the MicroTrack II, it will appear as a generic "Removable Disk" icon that was not there before.
3. Right-click on this new "Removable Disk" and select "Format..." (IMPORTANT: If you have other removable disks connected to your computer, then you MUST make sure you select the correct disk before moving forward).
4. From the "File System" pull down menu select "FAT32".
5. Click "Format" and "OK" in the following confirmation dialog.
Mac: A 512MB or larger compact flash is required*
1. Connect the MicroTrack II to a USB port on your Mac - it will power up in USB mode and will be recognized as a new disk entitled "No Name" and will be mounted on your Desktop (if the MicroTrack was already powered on, select System->Connect to PC)
2. From the menu on top of the screen, select "Go", then "Utilities" and then double-click "Disk Utility".
3. Select "M-Audio MicroTrack Media"
4. Select the "Erase" tab
5. From the "Volume Format" menu, choose "MS-DOS File System".
6. Click "Erase" in the main window and "Erase" again when a confirmation message is displayed.
* The Rescue Disk procedure used in this guide requires a compact flash card with a FAT32 volume format. OS X's Disk Utility automatically (DOS) formats media with a size of up to 256MB in FAT16.
Posted on Jan 02, 2008
  • 1,944 Answers
I suggest that you to select Reset to Factory Defaults in the System menu to soft reset reset the unit or by pressing Delete and the power button and holding them down to hard reset. Good luck!
Posted on Dec 14, 2007
My webcam won't let me take pictures on face book and it said to reset,what does that mean.
Step 1:
Go to Facebook and log into your account. Click the "Profile" tab. Click the "Video" link in the "Status" menu. Select the "Record a Video" option. For privacy reasons, Facebook requests permission to access your webcam and microphone. Check the box next to "Allow" and click "Close." You will appear in real time on the Facebook webcam window. Position yourself in front of the webcam and click the red "Record" button to begin recording your new video. When you're finished, press the "Stop" button. Click the "Play" button to view your video. If you want to post it on your profile, add a brief message and click "Share." If you're not satisfied with the outcome, press "Reset" and record a new video. b> Video Message Log into your Facebook account Navigate through your friends list and select the friend you want to send a video message to on Facebook. Click the "Send Message" link in the upper-right corner of your friend's page. Click the "Video" icon in the attachments section at the bottom of the "New Message" window. Check the box next to "Allow" to give Facebook permission to access your webcam and microphone, and then click "Close." Press "Record" and record your new video message. Click "Stop" when you're finished recording. When you're finished recording, you can press "Play" to preview your video.
Feb 12, 2013 | Acer eMachines 520-2890 Notebook
My tascam dr 100 gives a 'writing failed' file error' message and stops recording
Try using a smaller memory card. This only happens to me when using a 4- or 8-gig card. 2-gig and below, No error.
Feb 24, 2012 | Tascam DR-1 MP3 Player
How do I delete old recordings off my RCS digital voice recorder?
Press Menu,with the down arrow,scroll down to "folder",press red button. A list of folders will appear.Scroll down to the folder you want, press red button.Now scroll to "file" , push red button.A list of files will appear pick the file you want to delete, push red button.A list will appear with "select" on top, scroll down till you get to "delete" , push red button. A message will ask you are you sure. Use the arrows again to go to "yes" then push the red button again to finalize your delete.
Nov 27, 2010 | Zoom H2 Digital Voice Recorder
How do you record your own ogm on a Tesco ARC 402 ansa machine phone. I have a pre recorded message but want to change to a personal message
press PROG, use the up and down keys to select TAM (stands for telephone ansa machine) then select ANSA and Record, then OGM, then personal. The phone will immeaditately start recording so you need to be ready to speak, when you're done press the green phone/ok button to finish. then press the red button until you return to the main phone screen. now press the OGM button on the base unit and you should hear your OGM personal greeting.
Oct 09, 2010 | Cell Phones
Cannot operate svr-925 digital recorder, need manual
How to Record:
1. Make sure HOLD switch (on side of unit with pocket clip) is set to off position (slide to right is off - to left would be hold)
2. For best results set unit with mic(rophone) which is on top of unit toward sound source and press REC/STOP button (Top button on front of unit just below LCD display). Recording will begin and will be indicated on LCD display.
> Red Record LED will be on and the message number, recording time will be displayed on the LCD.
3. To stop recording, press REC/STOP button one time.
* If no other buttons are pressed within 1 minute at stop position, it will power off automatically.
4. Pause during recording by simply pressing MODE/PAUSE button- press button again to resume.
There is a Voice Operated System (VOS) Recording button on left side also. You can record with voice activation to conserve recording space but I have found that you lose a portion of the recorded sound as it activates and if there is no sound for a very few minutes the unit powers off and you will get nothing further recorded. I recomend just keeping VOS in off position.
5. To erase a recording: Select the message number you want to erase and while it is stopped (the message number will appear in LCD with the length of recording showing also)
Press and hold the ERASE button until the LCD begins blinking "ERASE" then, while it's blinking simply press the erase button again and the recording will be erased.
6. To play back a recorded message find your message by "toggling" the switch on the right side of the unit that says INDEX. That switch is the fast forward/reverse play etc. To Play simply push the switch in. This button/switch takes a little practice to use but the Play portion is straight forward. Use the front buttons to pause and stop during playback.
Hope this helps.
Jan 04, 2009 | Sims SVR-S825 Handheld Digital Voice...
I want to leave my own answering message on my voicemail, how do I do that?
Press Menu. Then the unit will say "record outgoing message" Press the REC/Memo button and the unit will say "recording" and beep. The display will start counting in seconds. Speak your message. Press the play/stop button to stop recording the message will be played back to you.
Sep 22, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Freezes while recording
I'm been searching for slutions to this as well - It's happened to me numerous times, so much so, I've almost thrown it on the ground to see how many pieces I can break it into...
Apr 11, 2008 | M-Audio MicroTrack 24/96
Frozen hard drive
Hi this Greynut i have resolved my problem this is what i did press menu then setup press ok then scroll down to the help symbol then press ok then press the green button on your remote control and that will bring up the page settings and what i did was press the red button which is factory defaults that will take your set top box back to the factory settings you will loose your recorded programs but it will be like new setbox again you will have to follow set up instructions and re tune your set i have got all my disc space back now and no problems with screen freezing or set top going off i hope this helps you.
Feb 14, 2008 | Televison & Video
Won't record
Sounds like you are pressing the red button twice. The first time starts recording and the second time closes and writes the file to the memory card. If you don't think you are pressing the button twice, you may have a bad unit. Make sure you have checked with M-Audio to get the latest software before you reject it as a bad unit.
Dec 14, 2007 | M-Audio MicroTrack 24/96
User manual for a Bellsouth answering machine model 1188
Found my manual!
To set the time, press and hold the time/code button for 2 seconds. You will hear "TO SET CODE PRESS TIME AND CODE BUTTON."
Release the time/code button.
Press the 2 way/m button once. You will hear "SET DAY AND TIME, SUNDAY"
Press the << or >> button until you hear the correct day.
Press the time/code button once. You will hear "TWELVE"
Press the << or >> button until you hear the correct hour.
Press the time/code button once. You will hear "OH".
Press the << or >> button until you hear the correct minutes.
Press the time/code button once. You will hear "PM".
Press the << or >> button if you need to change to AM.
Press the time/code button once and you will hear the complete time and day setting.
To record an outgoing message, press and hold the ogm button. Release the ogm button and start to record after you hear "PLEASE RECORD AFTER THE TONE" followed by a beep tone. When finished, press the ogm button.
Make sure you put a battery in the answering machine so you don't lose these settings if the power goes out!
Nov 11, 2007 | Lands Phones
M-Audio MicroTrack 24/96 Logo
644 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
