Question about Cameras
Samsung nv10 i have a nv10 samsung the lens got stuck and was pushed back in it does everything its suppose to except take a picture it turns off because of the lense being stuck
  • 1 more comment
  • Anonymous Dec 24, 2007
    im turn on the camera but tle lent get blocked and the camera torn off again
  • frrann Jan 07, 2008
    Yep! Same problem too - the lens has stuck out and won't go in or any further out. It won't switch on and therefore cannot connect with my pc as it cannot be recognised.......I am waiting to hear from Samsung - I have had the camera 5 months!! No dropping or accidents.....
  • Anonymous May 27, 2008
    same problem must be common manufacturing fault
I too have this problem. I sold the broken one on ebay, and bought a second hand one and low behold - it TOO has a stuck lens.
unfortunately warrentey ran out months ago. How depressing.
Posted on Jan 17, 2008
I have a digital camera samsung NV10 - i was just using it and then the lens got stuck and the camera turned off. I even tried removing the battery and memory card and putting them back in. I then tried to...
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Sep 04, 2010 | Samsung NV10 Digital Camera
The lens piece that retracts when you turn off the camera and opens when your turn it on is not working. The Samsung NV10 will not open when turned on and makes a ding,ding sound and turns off. Any...
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Regards
Andrea
Aug 22, 2010 | Samsung NV10 Digital Camera
Samsung nv11 - camera dropped and now lens stuck; won't go back in...please any suggestions? thanks
thanks! found the similar problem listed for the NV10...still trying them out!
Jan 01, 2010 | Samsung NV10 Digital Camera
Ok my camera lens got stuck...so i fixed it...the fix didnt last long as after 10/15 mins it got stuck again...and keeps gettn stuck so now to take a picture i have 2 pull the lens out every time...what...
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Dec 29, 2009 | Samsung NV10 Digital Camera
Lens is stuck open - will not close. still takes pictures
you must have dropped your camera where it caused damage in internal part. when cameras are dropped wires and screws inside loosen which will cause trouble. Have it checked by a pro. you might destroy it more if you try to fix it yourself. Thanks.
Nov 24, 2008 | Samsung NV10 Digital Camera
Samsung NV10 heeelp!Pleeease
Not sure about the battery... that could be it and I haven't tried switching it out for a new one yet, but in the meantime I am getting around this problem my grabbing the lens with my fingers and "helping" come all the way out... just give it a little pull, a little encouragement and it will come all the way out... but the trick is that you have to do it right after you try to turn it on and before you get the beeps...
So if your lens is stuck out right now and the camera is powered off, then turn the camera on and then pull the lens out before you get the beeps... once you give it a little tug, the mechanics should take over and it will extend all the way... the LCD will come on and you'll be good to go...
Like I said, I'm having this problem too and my girlfriend suggested we change the battery... I guess that's possible, that the battery is not holding enough of a charge to push the lens all the way out... I'll investigate how much a new battery costs and then determine if I think its worth a try...
Jul 10, 2008 | Samsung NV10 Digital Camera
Samsung NV10 lens won't retract/Autofocus doesn't work
please check your manufacture warranty as my samsung nv10 comes with a 2 year warranty
Feb 13, 2008 | Samsung NV10 Digital Camera
The lens is jammed.
This is a result of damage to the gear in the motor asssembly.
The gear teeth have been broken off & as a result the gears that drive the opening& closing of the barrel dont mesh together resulting in the jam and your 4 beeps!!
Jan 24, 2008 | Samsung NV10 Digital Camera
Samsung NV10 - 4 bleeps on switching on then turns off
my camera started doing the same exact thing, did you ever get an answer?
Jan 20, 2008 | Samsung NV10 Digital Camera
Cameras Logo
404 people viewed this question
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
