Question about SanDisk Sansa m230 MP3 Player
Can you get the menu button replaced?
It has become loose doesn't correspond and hard to push. Half of the time it doesn't turn on. I have 2 others and they work just fine and the button has a little spring to it when pushed. Is it possible it can be replaced? If so where?
  • 8,596 Answers
Not possilbe - you must replace the whole player - call Sandisk
Posted on May 26, 2008
How to hard reset prestige eliet visual land tablet
Hard Reset To hard reset your Visual Land Tablet, you need to follow the instructions below carefully.
1. Turn off the tablet.
2. Press and Hold Volume Up and Power button at the same time.
3. Keep holding the buttons till you see the start up screen.
4. Press Volume up five times when you see the android with an exclamation to reveal the recovery menu.
5. Since touch screen doesn`t work on this mode use Volume and down to move on the menu and power button to select.
6. Select Wipe Data/Factory Reset.
7. Select Yes- Delete all user data.
8. After the wiping select Reboot System Now.
Apr 01, 2017 | Tablets & eReaders
Remote stopped working. How does one reset the remote?
Programming a code into a remote mode:
  1. Turn on the component to be programmed, then press the corresponding MODE button on the remote control. (TV, VCR, AUX, CABLE, ETC)
  2. Press the MENU and MUTE buttons simultaneously for 2 seconds, the button selected component lights on the remote control. If you don't press any button for 20 seconds, the button selected component will turn off on the remote control.
  3. Enter a code number using the number buttons on the remote. When pressing the button, the light is blinked at a time. Programming codes for the corresponding component can be found on the following website. Again, if the code is correct, the device will turn off.
  4. Press the MENU button to store the code. After blinking twice, this code is stored.
Jul 18, 2011 | LG 42LC2D 42 in. LCD HDTV
My phone wont turn on
Try a battery pull.
If that doesn't work, try a Hard Reset.
Hard Reset
1. Power off phone
2. Use hardware keyboard
3. Press and hold the 'X' key and Power button until you see a screen with an exclamation point inside a triangle
4. Press and hold the Volume Up key then press the Camera button (I had to do this twice) to get menu screen (Linux back-end becomes VERY apparent here)
5. Using the D-pad, select one of the Wipe options (specifically Wipe Data/Factory Reset)
6. Confirm your selection and wait for it to complete
7. Reboot the device
if the problem still persists, your phone might have water damage and may need replacing.
May 30, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
Erreur 5b00 sur canon pixma mp450
1. Turn off the printer ( "Power" button).
2. Open printer cover and hold the button "Resume" (red circle in the triangle) and push and hold Power button.
3. Release button "Resume" and then push button "Resume" 2 times and release both buttons.
4. When printer become ready on the display write "CANON Idle".
5. Now close printer cover and push button "Resume" 4 times.
6. Then push "Power" button 3 times to turn off printer.
All done. The printer is ready to print.
Dec 28, 2010 | Canon PIXMA MP450 All-In-One InkJet...
ERROR 5B00, no me deja imprimir
2. Hold the button "Resume" (red circle in the triangle) and push "Power" button.
3. When printer become ready hold the button "Power" and release button "Resume".
4. Push button "Resume" 2 times and then hold "Resume" and release "Power" button.
5. When I hold button "Resume" I push and hold "Power" button and release "Resume".
6. When I hold "Power" button, push button "Resume" 2 times and release both buttons.
7. When printer become ready on the display write "CANON Idle".
8. Push button "Resume" 4 times.
9. Then push "Power" button 3 times to turn off printer.
Nov 22, 2010 | Canon PIXMA MP180 All-In-One InkJet...
I am having problem taking the back off my R-9500 Electric Shaver, I removed 2 screws, one at the bottom & other near button for trimmer. I have pushed the the trimmer button up to open the trimmer,...
The third screw is hard to see. To access it, you will need to remove the trimmer from the point that it pivots out from the shaver. Use a small flat screwdriver to gently pry the small plastic pegs from their corresponding sockets on the shaver body.
Sep 29, 2010 | Remington Titanium SmartSystem R-9500...
98 breeze door locks keep locking and unlocking while driving
You have button like things on your door jambs that you can push in by hand, that your door presses against when closed. When they become faulty, or door gets a little loose, this can happen. I normally open one door at a time & work those buttons by hand slowly to see if one acts different than the other, and watch interior light to see if it comes on & off, or has a delay in shutting of when I push button in. Normally the one acting different is that bad one & needs replacement, or even some contact spray (electrical) used on it will help temporarily. Even sticking a piece of gum or layers of tape on the end of the button to make it push in further for test drive can narrow it down. Do one a time, when problem stops, you found the culprit. The other option is to check & see if one door feels loose compared to others by pushing in slightly on them.If you do find one that seems loose, adjust striker in a bit where door latches, to make it tight as the others, and that may just do it too.
May 29, 2009 | 1999 Plymouth Breeze
False empty toner reading
The problem can be may this however hard resetting it can fix the issue
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
Jul 12, 2008 | OKI C5500n Printer
Remote control not working
have you program first the remote control, to work on your TV..??
Heres a few instructions how to programmed your remote..
  1. Test your remote control. To find out whether your remote control can operate the component without programming, turn on the component such as a VCR and press the corresponding MODE button (VCR) on the remote control, while illuminating on the selected component. Test the POWER button to see if the component responds properly. If not, the remote requires programming to operate the device.
  2. Turn on the component to be programmed, then press the corresponding MODE button on the remote control.
  3. Press the MENU and MUTE buttons simultaneously for 2 seconds, the button selected component lights on the remote control. If you don't press any button for 20 seconds, the button selected component will turn off on the remote control. At a moment, you have to repeat from step 2.
  4. Enter a code number using the number buttons on the remote. When pressing the button, the light is blinked at a time. Programming code numbers for the corresponding component can be found on the following pages. Again, if the code is correct, the device will turn off.
  5. Press the MENU button to store the code. After blinking twice, this code is stored.
  6. Test the remote control functions to see if the component responds properly. If not, repeat from step 2.
Try 001 as the PCode.
Thanks..
May 08, 2008 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
SanDisk Sansa m230 MP3 Player Logo
22 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
