Washer leaking water from underneath
My husband and i found the problem. The drum in the middle of the washer is not centered so when i turn the water on it the water leaks out. how can we fix that problem?
    Sergeant:
  • 239 Answers
You will have to level the washer so that when its done spinning the drum is in the center if the machine. Just use a level or you can even use a glass of water if you don't have a level. once the legs of the washer are all right you should not have a problem. Happy Holidays bear001 Let me know
Posted on Dec 14, 2007
I have a leak somewhere.where could it come from?
check the pipes from the water main and the pipes in the machine could be a seal has gone
Feb 19, 2016 | Kenmore HE2 Plus Front Load Washer
Clothes left with grease smears
There are two real possibilities, both are in the washer. The first is
that the gear box seal is failing, and the second is that the fabric
softener dispenser needs to be dismantled and cleaned out.
"When the seal starts to fail, this oil floats up into the wash water
in the form of small black drops. The stains are almost impossible
to remove from clothing. Also, as the oil is leaking up, hot soapy
water is leaking down into the transmission, which will eventually
cause it to fail. As I recall, the seal wasn't difficult to replace,
but to get access to it I basically had to disassemble the whole
machine. The hardest part was pulling the agitator off the shaft - I
used a slide hammer puller. I'd start by pulling the agitator off and
see if you can access the transmission seal that way
Apr 15, 2008 | Frigidaire GLTR1670A Front Load Washer
Water flow on floor ?
my washer is not a front load or a fancy one, but my problem was also a leak coming from under the middle front of the washer. It was the water pump and once replaced, haven't had any more problems! It was a real simple fix, My husband was able to replace it in about 10 minutes, with a pump I found on ebay!! We found how to replace it on youtube!!!!!
Jun 07, 2014 | Kenmore 45081 Front Load Washer / Dryer
1)changed the thermostat? 2) thought it was heating core, they by passed that? 3) Husband thinks it could be the frost plug? Water keeps leaking out and overheating, the water leaks from the middle of...
Find your water pump and put your finger right under the bottom of it and rub it, see if you get water from there on your fingers. If so change your water pump. If that is not the problem, go underneath to where the drip is and follow the stream up to the starting point of the water leak, The bottom of the motor is only the lowest point for the water to drip off.
Sep 08, 2010 | Dodge Intrepid Cars & Trucks
My kenmore washer has just started this week leaking water underneath somewhere!! I noticed water down the side next to the wall & behind the washer. I then placed a few small towels behind & down...
This is either your water pump, inlet valve, or you have a hole at the top of the outer drum. Try using the small load water level, if no leaks try medium. Also try seeing if the hoses are leaking. I also have seen mice bite holes in the drain lines. I hope i have helped you. God bless!
Aug 20, 2010 | Kenmore 26442 Top Load Washer
Ultimate care supreme leaks underneath
First check the hoses to the machine. If they leak the water follows the hoses and drips on floor. Also check the hose connection at the washer. They will leak inside. Next it may well be a water pump going out or the plastic hose that is under pressure when operating. The pump is in the middle of machine underneth - Sorry - Good luck
Oct 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a 21 year old Kenmore washing maching (model 82873800). It is leaking when it is filling up. The water is not coming from the hoses or the center shaft. When I lean the washer over, I can reach...
I'd go to the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.82873800%29
and check the sub-components lists for a gasket or part under the tub that keeps the water from leaking.
With a 21 year old washer, it's likely that one of the rubber or plastic gaskets has finally worn.
Sep 20, 2009 | Kenmore Washing Machines
Leaking from bottom front
lean washer to back ..pump mounts just underneath 2 clips hold pump too motor shaft remove clips remove hose clamps ckd pump most likely suspect for leaks
Sep 02, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore front load washer
check teh rubber seal on teh front door. They sometimes leak down the front of the door.
Jan 14, 2008 | Kenmore 44832 Front Load Washer
Washer leaking water from bottom
You may want to check the seal at the bottom of the agitator, there is a o-ring that keeps the water in the drum from leaking through the agitator as it spins. This is a cheap seal and will wear over a period of time from exposure to bleach and detergent. You need to take the agitator apart and remove it from the drum and you should see this seal at the base of the agitator were it meets the drum.
Replace the seal and reassemble, take the metal casing off the washer and fill the drum with a little water, wait, and see if the water is leaking under the drum. If no leak, try to reassemble and run the washer. If is still leaks then check http://www.applianceaid.com/genew.html
Yours Truly,
Mr.Fix-it-guy
Jul 30, 2006 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
132 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
