Linksys router packets
Sent packets won't receive
  • sajpel Jan 12, 2009
    linksys is connected and connection is excellent but it wont go on the internet and it only sends packets and doesnt recieve them
    Master:
    Sergeant:
  • 482 Answers
You have to call your phone company to get them to set it up
Posted on Dec 16, 2007
Wi-fi extender
using a wireless uplink sucks and most equipment won\'t do it and the ones that try suck at it.
that said:
-set the 1st router up normal
-set the second router up EXACTLY the same (SSID/password)
-now change the IP on the second router so that if the 1st is 192.168.1.1 the 2nd is 192.168.1.2
-last turn off dhcp on the second router
-NOW run a ethernet from the 1st to the 2nd and plug it into any port but the internet port. (that port won\'t be used anymore)
-ta-da! 2 networks but as far as your wireless device is concerned they are the same 1.
i have done this many times.... I have 3 routers at my place and can walk the whole length of my condo without losing a single packet!
Nov 06, 2013 | Computers & Internet
All lights on wireless router blinks what is the problem
The LEDs will blink when working properly, It is tramsmitting and receiving data packets to and from your computers and devices. If it stops blinking you may have a problem. Even with all device turned off, the ISP moden and the Linksys still transmit and receive data. It's a constant communication of, "are you there", "yes I'm here", 'are you ok", "yes i'm ok", you get the idea.
Dec 22, 2012 | Linksys WRT310N Wireless Router
Flicker prob
Welcome to Fixya.
Firstly, is it detecting your wireless router? Is the wireless switch on?
Try to restart both the laptop and the wireless router. Wait for 2 minute then start it again. Check whether you have a wifi signal on the buttom right on the screen. Put your cursor on the signal and go to network and sharing. It should say local and internet. or connected excellent . If not, try to type in cmd right click and hit run as administrattor. then type in ipconfig /all check the ipaddress and default gateway. if its a valid ipadress like 192.168.1.1 for linksys. and default gateway is the same. Check your internet explorer. Ping www.yahoo.com get a 4 packet sent = 4 packet received. . If the ipadress is 169.1.0. 254.. you need to go to cmd/ ipconfig /all then netsh winsock reset catalog; or check this website: http://support.microsoft.com/kb/299357
Hope this resolved your issue.
Thanks for contacting Fixya. Bye for now.
Jul 16, 2011 | Computers & Internet
My router will not connect the power light keeps blinking
Check this tip out from Linksys. It is for a G VPN Router but you could use the same steps to troubleshoot. Title: Resolving Blinking Power or Diag LED on a Linksys Wireless-G VPN Router Article ID: 4982 If the Power LED on your Linksys router is blinking, this means the device is not ready. It should go off once the router completes its diagnostic test. If the Power LED won?t go off, it indicates that there?s a possible hardware problem with the router. To resolve this, you will need to perform five steps: Resetting the Router Assigning Static IP to the Computer Pinging the Router Accessing the Router?s Web-based Setup Page Updating the Router?s Firmware For instructions on how to reset the router, follow the steps below. Resetting the Router Hold in the RESET button at the back of the router for 30 seconds. Unplug the power to the router then plug it back in. If after resetting the router and the Power LED is still blinking, try resetting the router again for another 30 seconds. Then proceed with assigning a static IP address on the PC. For instructions, follow the steps below. Assigning a Static IP Address on Your Computer Most of the time, if the power LED on the router is blinking it loses its ability to assign IP addresses to the PCs connected to it, which is why you need to assign the computer a static IP address. After assigning a static IP address on the computer, check if the computer is still communicating to the router by performing a ping test. To ping the router, follow the steps below. Pinging the Router Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection. In this example, our router IP address is 192.168.1.1. NOTE: If you?re using Windows 98 or ME, click here. Windows 2000/XP Step 1: Click Start, then Run. Step 2: When the Run window opens, type ?cmd? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. Windows 98/ME Step 1: Click Start, then Run. A window similar to Step 2 will appear. Step 2: When the Run window appears, type ?command? in the Open field, then click OK. Step 3: When the MS DOS Prompt appears, type ?ping 192.168.1.1? and press [Enter]. Step 4: Check the ping statistics. You should get Packets: Sent =4, Received =4, Lost = 0 (0% loss). NOTE: If you?re not getting good replies from the router, it means the router is not communicating properly with the computer anymore. You can already consider the device defective. If you get good responses from the router, access the router?s web-based setup page to see if a firmware update is possible. For instructions, follow the steps below. Accessing the Router?s Web-based Setup Page In order to perform a firmware update, you should be able to access the router?s web-based setup page. Updating the firmware is one way of resolving the blinking power light on the Linksys router. To access the router?s web-based setup page, click here. NOTE: If you?re having difficulties accessing the router?s web-based setup page, the router is considered defective. If you?re able to access the router?s web-based setup page, proceed in updating the firmware upgrade.
Jul 21, 2010 | Linksys Wireless-G Broadband Router
This is my modem log any ideas for a solution to my random DC's
The router actually has major issues. First, check the power cord to make sure that it's operating in the right voltage.
If it is, then through the command line type tracert followed by a website. If there is no response from the first address, then it will not detect the router.
If this happens, change the router.
Aug 09, 2009 | Arris SURFboard® SB5101 Cable Modem
Xbox live MTU failure
The reason why you're getting an MTU error is because the MTU has already reached the maximum # of packets that are being sent. To resolve it.
Access the GUI of your Linksys Router and go to the MTU settings. Set it to 1500. The lower, the better
Apr 26, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys wireless connected to router, signal fine, no web pages
First thing i would try is power cycling your equipment. Unplug the router and the Modem-
Plug the modem in first and once all the lights come on- plug in your router- then restart your computer.
Apr 09, 2009 | Linksys Wireless-G WRT54G Router
CONNECTIVITY
Your new laptop,
Are you searching for a new wireless network? Then your router doesn't show up on the list of networks?
I can rephrase if need be.
Oct 18, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
127 people viewed this question
Alun Cox
David Payne
David Payne
