Question about Panasonic TH-50PX75U Plasma HDTV
Mounting TV Someone told me to but 1/4'' buy 1 1/2'' bolts to mount my 50 in panasonic plasma. The wholes in the back of the TV swollow those bolts. What size do I need?
They are a metric size, call Panosonic, I belive 8 x 15mm
Posted on Dec 31, 2007
Assume you are mounting on the wall, if so a good mount will have the standard bolts in the package. If this is a used mount, you will need to determine the length based on the mount, the bolt size is either 1/4" or 5/16", probably the latter.
Posted on Dec 14, 2007
What bolts/screws do i need for the holes at back of tv for wall mounting
The screws usually come with the mount. The size of the screws depend on the size and weight of the TV so there is no one answer.
Oct 22, 2015 | Panasonic TX-P42S10 42 in. HDTV-Ready...
What size bolt screws into the back of the TV to mount a wall mount
42" will more likely to use Metric M6 screws (canbe M5 but not likely), the length of the screws will depend on the thickness of the mounting plates. When you buy wall mounting kit, it will come with mounting screws. You can get Metric screw from HD or Lowe's for about 50 cents each.
I get my wall mounts from Costco and they come with a bag of Metric screws fro mounting.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Aug 06, 2011 | Philips 42PFL3603D/27 42 in. LCD TV
Need instructions
Flat Panel TV WallMounting Instructions
Currenttrends Flat Panel LCD and Plasma HDTV's are making TV's thinner, lighter andmore powerful. Superior high definition viewing, affordable pricing with addedspace and energy savings are only just a few practical reasons for purchasing anew HDTV. With newer thinner designs, LCD and Plasma HDTV's are ideal for wallmounting. Wall mounting your television frees up space and adds a new elementof aesthetic appeal to your home theater. Positioning Before getting into any hardware mounting,find the best possible position to mount your television. Because wall mountingan HDTV is more of a permanent solution, careful planning is needed whenintegrating the television into your home design.
Furniture placement, overall themes, viewing angles, and the best audiopositioning are all factors that will help determine the placement of the LCDor Plasma TV.
Once you have decided the general positioning of the wall mount installation,cut out a piece of cardboard or wrapping paper in proportion the of theflat panel television. Next, approximate the placement by taping the piece ofcardboard or wrapping paper to the wall where the TV will be placed and mark itwith a pencil.
Preparing the TV Removethe stand from the television and lay the TV on its face. Locate the fourmounting holes on the back of the television and remove the bolts. Next, removethe mounting arms or mounting plate from the wall mount packaging.
To attach mounting arms, line up the arms vertically and parallel to each otherusing the mounting holes on the back of the television. Make sure that they arein perfect alignment and bolt the arms using the bolts and washer supplied withthe wall mount.
If you are using a mounting plate, simply line up the holes with the mountingholes on the television. Secure the mounting plate with the bolts and washersincluded with your wall mount.
Preparing the Wall Locatethe studs closest to the desired position using a stud finder and mark themwith a pencil. Remove the wall mount from the package. Line up the wall mountup to the studs within the center of the marked position you determinedearlier. If it is not perfectly centered, wall mounts can be adjustedhorizontally at a later time.
Using a level, line up the wall mount and mark the positioning of where hebolts will go. Drill holes into the stud about 1" deep, drill bit depends on the of bolts supplied with the wall mount. Bolt the wall mountto the wall with bolts and washers, but don't tighten down the boltscompletely. Adjust the position of the wall mount left or right to center it toyour desired position. When you are done, tighten the bolts the rest of theway. Mounting the Television Attachingthe television to the wall mount takes two people. Simply lift the televisionand hook it to the wall mount. At this point you can further adjust thepositioning horizontally to center it perfectly. Once the desired position isacquired, tighten down the screws that attach the mounting arms or plate to thewall mount.
mike_alozie.jpgWallMounted LCD
Apr 21, 2011 | Televison & Video
Panasonic TC-P54S1 mounting hole pattern
See page 8 of the manual at: http://service.us.panasonic.com/OPERMANPDF/TCP42S1.PDF The bracket shown there looks like the mounting holes (4?) are vertical on the back of the TV. They may be identified by an arrow pointing to them. There will be two holes on each side of the TV centerline to attach the vertical components of the bracket that hang on the horizontal angle bars on the wall.
Oct 06, 2009 | Panasonic TC-P54S1 54 in. Plasma HDTV
Want to mount but don't know how
Buy a mounting bracket first and it will give you all the instructions you need.
Mar 29, 2009 | Panasonic TH50PZ80BPED 50 in. Plasma TV
Insignia(samsung) 50" plasma Vertical red lines
I would take it back. I know from purchasing an Insignia LCD from them a while back, the TV just died after about 4 or 5 months. They ended up offering me another TV or with store credit. I took the store credit and chose another TV. I also did not have a warranty. I was told since it was Insignia (which is a Best Buy house brand) that replacing it was not a problem. Good luck.
Nov 25, 2008 | Samsung Televison & Video
Mounting to TV Stand
there are two types of stands, some are wall type which needs to be mounted using rawl bolts, nuts are suppose to hold a stand, some are ground stands which are suppose to be put on a flat surface in order to balance.
Jul 29, 2008 | Panasonic TH-50PZ77U 50" Class Plasma HDTV
What size bolts for mounting bracket??
I don't know the size but, I can bet it will be a metric bolt.
Apr 17, 2007 | Zenith Z50PX2D 50 in. Plasma HDTV
Panasonic TH-50PX75U Plasma HDTV Logo
840 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
