Question about Canon PIXMA iP4200 InkJet Photo Printer
PGBK Problem I have cleaned & deep cleaned the PGBK several times. When I print a "Printer Test Page" the density of the black letters starts out O.K. and becomes "fly speced" by the bottom of the page. Any sugestions?
  • 286 Answers
Make sure you are using Canon ink cartridges, and not generics or refills.
If good Canon cartridges do not solve the fault, there are two likely causes.
1. Your purge unit is damaged or clogged. Many times I have seen a printer work fine at the top of the page and poorly by the time it gets to the bottom. Many times this is solved by removing the purge unit and cleaning it. Most purge units have small rubber hoses that can become clogged with dried ink. I wouldn't suggest removing this unit unless you're technically inclined. You MAY actually have to remove the tubes from the pump in the unit and clean them before reassembling. I've seen many people get to this point and then fail to be able to reassemble.
2. Your head may be wearing out, or have cloggs. You can use the "Soaking Method" on most canon heads. Put some hot water in a cup. The cup should be wide enough to allow the bottom of the head to sit in it without allowing the entire head to fall in. Put enough water in the cup to cover the bottom portion of the head (the nozzles) only. Let the head soak overnight. Next day reinstall the head, do a few deep cleans or whatever the best type of clean your driver will give you.
Now, either everyhting will work fine or you'll find your cleaning cycle is not working, in which case goto step 1 above.
Our service centre does a strip and clean for $45. If it's less than half the cost of a new machine it might be worth considering taking it for service.
Posted on Dec 29, 2007
Canon PIXMA iP4200 not printing PGBK properly - only printing top 50% of PGBK grid on test page.
Man you did some awesome troubleshooting! I don't know, but it sounds like something is physically wrong with internal electronics. I'd call in the big dogs at Canon themselves.
Nov 17, 2016 | Canon PIXMA iP4200 InkJet Photo Printer
My Canon MG5220 is only printing colors. No black ink is being printed
Go to 'Printer properties' then 'maintenance', click 'deep clean' then select 'PGBK'. Test after cleaning and repaeat if still no print.
Feb 14, 2015 | Canon PIXMA Office Equipment & Supplies
Mp960 color prints ok but black and white not printing
When was the last time you printed in color? New ink printers are built so with a "use it or lose it" theme. The print heads are now built into the machines and are not generally replaceable. Yours luckily is, but I don't know how easily. The link below is to the replacement which costs $130 + shipping. Sometimes it can be just as worth it to buy a new machine, in this case I would probably prefer to repair the damaged machine as the new printer cartridges cost more and have less ink.
Feb 16, 2010 | Canon PIXMA MP960 Printer
I have problem with print-head for PGBK-5. On the test-print it does not appear as the pattern suppose to be (from the top) PGBK, C, C, M, M, Y, and BK. The pattern always appear C,C,M,M,Y and BK. I used...
if the clogging is worst then the deep head cleaning wont help.the head will need to be cleaned up manually and the waste ink pad in the printer should be cleaned too. this is covered normally in printer servicing.give special instructions to clean the head properly while you hand over the printer for servicing to any local tech. head cleaning and servicing will solve the issue
This will help. Thanks, please keep updated. please do rate the solution positively .thank you for using fixya
Dec 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
How do I direct my Canon ip4300 Printer to no longer print from the normal black 5BGBK cartridge (empty) but to print from the 8BK (full)
You can't because CLI-8Bk ink cartridge is use only for photo printing.For text, document or gray scale printing the printer use PGI-5Bk.You need to replace your empty PGI-5Bk.
Oct 19, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Printer not printing in black
Problem Solved --- Agree with the comment about "not buying the cheap ink". Stick with the Canon PiXMA (PGBK 5) and (BK 8) black ink refills. The printer can be cleaned and/or deep cleaned using the Menu Button to find this function.
Apr 21, 2009 | Office Equipment & Supplies
PGBK won't print -
Had this same problem with my 5 year old MP830. It was the print head. I bought a new one from Works like a charm.
Sep 10, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon MP500 PGPK cartridge wont print
i have the same problem too. This is obviously a product defect. If Canon not fix it, i wont buy Canon printer anymore.
May 21, 2008 | Canon Pixma MP500 All-In-One InkJet...
Prints black on test page, but not when a job is sent to the printer
make all your printer settings to default. If any problem in that simply uninstall & re-install the driver.
If still no good, your black cartridge might have dried-up
Oct 18, 2007 | Canon BubbleJet i560 InkJet Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
623 people viewed this question
old marine
old marine
