Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Color is messed up
All the color is messed up on the tv, and the convergence doesn't fix it. I think the tv was left on on an xbox 360 screen for a few hours by my sister. Please help.
    President:
  • 4,402 Answers
Sounds like bad convergance ic
http://www.techlore.com/forum/thread/18970/Sony-KP-46WT500-Convergence-Repair/
Posted on Dec 19, 2007
My xbox 360 causes my hdtv screen to crash and display colored static. It only does this on the 'optimal display' of 1680x1050. I plugged in my laptop on the hdmi and it worked perfectly. Is t
Try manually choosing lower resolutions in your xbox display settings. My Insignia HDTV does that when switching resolutions like on Hulu in between commercials and then back to the show but only for a second or so. Also does this when going from the loading screens to the game screens for a few seconds when playing the game Split/Second
Jan 10, 2013 | Microsoft Xbox 360 Console
I have an xbox 360, but i have a ps3 connect to the tv via hdmi. i swapped the hdmi cable to the xbox and powered on. i had all the cables in the correct position, the correct av selected on the tv, but...
Have you tried disconnecting the HDMI cable from both the TV and the console and then trying to reconnect?
Y+RT does not reset controllers for the Xbox 360, so not sure what you are attempting there?
What type of TV do you have? It appears the issue is with either your cable or the TV seeing that you are having the same issue with both your PS3 and Xbox 360.
I still think your first step should be to disconnect all cables from both ends and reconnect. (with poer off of all sytems of course) If this doesn't solve your issue then submit further information on your setup such as TV make and model and I can research other possibilities.
Jul 16, 2011 | Microsoft Xbox 360 Elite Console - Black
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
When i turn on my xbox the screen stays blank
No that has to do with heat sink issues might wanna check into that.
Jun 25, 2009 | Microsoft Xbox 360 Console
The screen on my xbox 360 looks distorted with color.
mayb the cords r messed up cuz mine were lik that but then we got new cords it fixed it......or mayb its the tv try another tv first then if that dont work get a new cord
Apr 10, 2009 | Microsoft Xbox 360 Wireless Controller
XBOX 360 to Samsung HCM5525W high def convergence issue.
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
Mar 03, 2009 | Samsung HCM5525W 55" Rear Projection...
Games won't work
the laser that reads the cd may be messed up but do not mess with it cause if that breaks then u r screwed
Aug 20, 2008 | Microsoft Xbox 360 Console
Xbox 360 has sound but no picture on HD setting
Is the tv rated for HD? if its not the inputs will be at a wrong voltage and will create that snow like effect.
Is the TV you normally game on HD?
Dec 16, 2007 | Microsoft Xbox 360 Console
PROJECTION TV Phillips 9P6031c103
this is what convergance looks like;
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
if pix is dark their is 6 adjustments knobs in the front of the tv under the screen and behind the plastic cover. the top three are the brightness bottom three is focus.
Nov 24, 2007 | Toshiba 53H71 53 in. Rear Projection...
Screen blank
use the towell trick! Wrap the 360 in 2 towells turn on and leave running for 15 minutes. It gets very hot but after the 15 minutes turn off the console and power it back on again and it should work. Dont know if this is a permanent fix but my 360 hasnt broken again so far. Dont ask me how but it works, google it if you like. It also cures the 3 red lights problem.
Jun 22, 2007 | Microsoft Xbox 360 Console
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
119 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
