Question about IBM ThinkPad T20 2647 Notebook
Bios utility What is the bios utility set up and what can I do with it?
    Scholar:
  • 181 Answers
If you don't know, I'd suggest that you leave it alone.
Bios (basic in and out) is the lowest level of system operations, and miss setting any one of them could make for a bad day for your laptop.
Good luck
Posted on Dec 14, 2007
How do I change the bios settings to boot from a dvd to down grade from windows 8 to windows 7 please.
Hi
To activate the BIOS utility, press <F2> during the POST while the
computer logo is being displayed.
To set the boot sequence in the BIOS utility, activate the BIOS utility, then select Boot from the categories listed at the top of the screen.
You can then choose the order in which the BIOS seeks bootable media. For your purposes the optical drive needs to be the first option. Do remember that during the boot sequence there are only about 5 seconds where it will say "Press any key to boot from CD......" after which it will revert to booting from the hard drive.
If you go to this site,
Drivers and Manuals
you can choose your model from the options lists and can then download drivers and documents which you may need after your downgrade.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 03, 2014 | Acer America Aspire Xc-105 Desktop...
NEC laptop stuck in Phoenix BIOS Setup Utility
While in the BIOS setup utility, go through the tabs/menus looking for BOOT sequence. Configure the laptop to boot from CD-Drive before any other drive. Have the installation CD in drive.Save the changes made to the BIOS configuration, and exit the BIOS. Reboot.
If the installation medium itself does not have a problem, you should be able to boot from it and have the opportunity to install the operating system.
Jan 29, 2014 | NEC Computers & Internet
I want upgrade bios ga 8simlh rev 1.0,but can not
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
Jul 16, 2012 | Gigabyte GA-8SIMLH Motherboard
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
Under (setup utility) save settings are all disabled. need to able (restore settings) (load default settings) (save set- tings). in settings utility. my name is joe. can u help?
The bios shouldnt block you from saving unless it cant do it.
If this computer is more than 5 years old you may want to replace the bios battery on the motherboard and try saving your settings again.
Also, check with IBM on how to erase bios password if it has one.
Good luck and be careful.
Mar 17, 2010 | IBM NetVista PC Desktop
Bios password set on Toshiba Satellite A214-S7437
Contact Toshiba as the bios setting as customized by vendors and they will be able to help you better.
Aug 24, 2009 | Computers & Internet
Cannot make changes to cmos setup utility
Just remove the CMOS battery and replace the new one i this the cost may be Rs 8 to 15. It will work surely or do in your motherboard reset the bios settings there will be one bios reset pin just see it careful.surely problems will be solved.If it is solved mail me at sathis_saas@hotmail.com.
If it is solved please say thanks !!!!!!!!!!!!!!!
************** All the Best **************************
Jul 08, 2009 | Computers & Internet
No processor bios update
Sounds like you need to flash the BIOS (UPDATE the BIOS).
Do you know how to do this? The way I do it is by setting up a USB key as a boot device and have the FLASH utility on there....
HERE IS A LINK
which contains files to create the FLASH utility either on:
FLOPPY
CD (via ISO IMAGE)
... as well as some guides on what to do and other helpful stuff.
Its worth noting that if you have made any changes to BIOS, they will be restored to the 'factory' settings when you FLASH in the updated BIOS.
This should work, let me know if it doesn't.
Mar 27, 2009 | IBM (09N5424) Motherboard
Motherboard
First reboot the computer and enter the bios screen. Disable the bios protect...
Then reboot back into the OS (Presumably windows) and download the bios update from the manufacturer website. It will probably be a zip file containg the bios and the flash utility. Unzip the file and you should have a windows and/or DOS flash utility. If not, the utility should be posted on the website. If the utility is Windows, simpy run the utility. It will ask for the location of your bios file. The update utility will do the rest for you. If the program is DOS, the procedure is similar. Move the utility and bios update into your root directory, reboot, and simpy run the program from the command line.
Nov 06, 2008 | Computers & Internet
Armada E500 BIOS reports wrong processor speed
Check Compaq's support site for any driver or utilities download for the chip set.
Aug 09, 2008 | Compaq Armada E500 Notebook
IBM ThinkPad T20 2647 Notebook Logo
35 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
