I have a Minka Aire remote control ceiling fan. The remote works fine with the fan control but the lights won't dim nor shut off. The remote indicates the model number as R520T but I'm not sure if that is for the whole unit or just the remote.
SOURCE: Minka Aire remote controlled ceiling fan
I have the same problem, except I live in a multi unit condo where many of the occupants own the same fan! You can imagine how frustrating this is when your fan or light comes on or you can't agree on a fan speed. Anyway, I spoke to a MinkaAire customer service guy and he tells me that the switches in the receiver are located under the mounting ring. You need to unscrew the ring and it should be located in there. I haven't tried this myself as my fan has a mind of its own as I type and everytime I turn it off to unscrew the mounting ring, the damn thing turns on again.
SOURCE: Minka aire ceiling fan
My Minka Aire remote is not working. When I use the remote nothing happens. When I turn on the switch using light switch nothing happens. I had it installed two years ago. Battery never replaced.
SOURCE: minka aire concept II ceiling fan bulb replacement
I found that the minka website has the installation manuals online.
www.minkagroup.net/http://www.minkagroup.net/minkaairemanuals.asp The glass cover on a Concept I fans turns counterclockwise. I had to use rubber gloves to get a good grip on the light cover.
SOURCE: Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
SOURCE: How to i replace the light bulb in the minka aire
i cannot turn the globe at all it is too stiff
