Question about Whirlpool LER4634PQ Electric Dryer
Dryer not heating
I have a Whirlpool LER4634PQ Electric Dryer, it runs but will not heat. What could be the problem?
  • 2 more comments
  • Anonymous Dec 21, 2007
    where is the heating element located on this dryer?
  • Anonymous Aug 15, 2008
    My dryer will not heat up, but it will run. The knob that you trun to set the dryer willnot move either. It is the knob not working or something eles.
    Thanks in advance,
    Tyana
  • kcandnola Dec 04, 2008
    My dryer is running, with heat, not drying. I have checked the vent in the back (the one that goes outside) and it is not clogged. I recently washed and dryed a blanket with much lint. I dont have any lint on the pull out part and I cant see any inside the unit. Is there some way to clean the chute? Thank you
  • techjon33 Jan 20, 2009
    I have the same problem, I took off the back panel and would like to know which one to replace for the heater element. I know that its is a thermister or a heater resister but not sure which one would one to replace to bring back the heat in my dyer, can anyone helpme?
Either the vent is plugged and the moisture is not escaping, or the element is no good. the failure mode for a dryer heating element is to open circuit.
Posted on Dec 14, 2007
My whirlpool dryer LER4634PQ0Runs but doesnt heat up?
It could be a number of things, but i would start with these first:
THERMAL FUSE.
The thermal fuse is designed to prevent the dryer from overheating. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
There are also a couple of 'thermostats' that could be the problem:
The 'high limit thermostat' is a safety device mounted on the heating chamber and is designed to prevent the dryer from overheating when the exhaust vent is restricted. A restricted vent will cause the high limit thermostat to trip or activate, interrupting the circuit to the heating element or gas valve. The high limit thermostat is not designed to activate repeatedly like a cycling thermostat and will eventually fail causing a no heat symptom. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter. If there is no continuity then it will need to be replaced and the restricted vent system corrected as well.
OR:
Cycling thermostats control the temperature inside the dryer drum. They are designed to "cycle" the heating element on and off to maintain the correct amount of heat. Cycling thermostats are normally located on the blower housing or elsewhere in the internal airflow ducting. Over time, the cycling thermostat can become defective. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter.
I hope this helps you fix the problem.
Dec 02, 2013 | Whirlpool LER4634PQ Electric Dryer
MY DRYER WON'T HEAT.
This is usually caused by a blown thermal cut-off which blows and cuts power to the heating element due to the failure of the high limit-thermostat to cycle off and regulate the heating element temperature. Check the dryer for clogged lint screen and/or restricted vent system then replace both thermostats when either of them has failed. Both are located on the blower housing.
Click on the links below for the detailed troubleshooting of this dryer problem. Just follow the instructions that are applicable to your dryer since you did not specify the dryer's exact model number.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Bottom Panel) Running But Not Heating
Jun 17, 2011 | Whirlpool Dryers
Dryer wont heat
The problem is likely the thermal cut-off and/or the high-limit thermostat if the dryer runs but doesn't heat. Verify this by bypassing the thermal cut-off and the high-limit thermostat. Click on the link below for the detailed troubleshooting.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 18, 2011 | Whirlpool GEW9200L Electric Dryer
Whirlpool dryer: Running but hot air stops coming.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 13, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer runs but does not heat
heatman101
Sep 01, 2010 | Whirlpool LER4634J Electric Dryer
Dryer is not turning on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
32443
Aug 09, 2010 | Whirlpool LER4634PQ Electric Dryer
I have a whirpool dryer model ler4634pq. I will not heat. I had the heating element and replaced the theromstats on the element but it still does heat. I had the switch checked. I checked to make sure hose...
heatman101
Apr 13, 2010 | Whirlpool LER4634PQ Electric Dryer
Dryer will run but does not heat up
Either bad heating element or missing one leg of the 240V circuit. The motor runs on 120V.
Sep 24, 2009 | Whirlpool LER4600 Electric Dryer
The dryer is heating on air fluff.
Good Afternoon,
Is this dryer Electric or Gas?
Mar 27, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool duet dryer runs but will not heat.
do you have 240 at the terminal block on the back of the dryer if so check for continuity on the thermostats , thermal fuse and heating element
Dec 29, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool LER4634PQ Electric Dryer Logo
253 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
