Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
932212344682 convergence ic's
Are these hard to replace?
Do they just plug in?
I have ordered the replacements and
I am just wondering how big of a job I am getting into.
    President:
  • 4,402 Answers
Http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 14, 2007
Hitachi 61swx10b HDTV - Convergence problems. User 'gdroukas' mentioned in a post that it is probably the convergence amps and a few resistors that have changed value. Can anyone be a bit more specific? ...
Convergence ICs are Big Black ICs and will have the part number on them. STK392-110,
upgrade to 120s or 150s better ICs.
Resistors to replace are RK42 3.3ohms, RK46 1.8 ohms, RK50 2.7ohms,RK54 1.5, RK58 3.9 ohms. RK62 2.2ohms
Mats Electronics has STK ICs 1-800-628-1118 order convergence Kit that comes with resistors.
ACME has the Convergence resistors they must be 1 watt resistors 1-800-575-9833
Let me know if you need any more help Thank You.
Jan 13, 2011 | Televison & Video
Television has double images like 3D, and bottom half of screen has a concaved image.
Please replace convergence ICs in tv, there are two big black ICs that has number STK392-110 mounted with big aluminum heat sink, replacement these ICs will solve your tv problem. Also check big resistor nearby these convergence ICs and replace if found burn mark or color faded.
On circuit board, IC location number is IC7001 and IC7002
Let me know if you have additional question.
Thanks.
Dec 25, 2010 | Panasonic PT-47WX49 47" Rear Projection...
I have a Samsung Rear Projection TV with a red convergence problem. Will replacing the deflection board fix this problem?
No you have 2 convergence ICs replace them if you havent and look for burt resistors near ICs 2.7ohms most of the time 2 of them need to be replaced They are Big Black ICs will have part# on them STK392-020s order parts from Mats 1-800-628-1118
Sep 16, 2009 | Samsung HCL4715W 47" Rear Projection...
Convergence
Good Day, Hazardsneon;
No, one portion of an IC could fail, but don't replace the one that failed, replace both. Good Luck, big IRISH.
Sep 07, 2008 | Mitsubishi VS-45603 45" Rear Projection...
Mitsubishi WT-46805
Good Day, Bosjerry;
I believe the IC's are on the left of the TV, looking from back, the TV uses STK 392-040 (two) convergence IC's. They will be mounted on a large heat sink (large silver/metal) looking device.
Good Luck, big IRISH>
Aug 01, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Blue red and green lines thorugh 1997 Sony 50" rear projection
Confirmed Hitachi subs all STK392-110,120 and 150 to
STK394-160 ....I use Hitachi part number CZ 01341 = no re-calls
..................T.
Feb 19, 2008 | Sony KP-46WT500 46" Rear Projection...
CONVERGENCE
Your Ics are bad and you prob have a resistor or two that have gone out too. If you are good with a soldering iron and have an hour to give up you can fix it. They are at location 7044 and 7045 on your board. They are STK 392-120's and the part number is 932212344682 good luck with you repair.
Feb 06, 2008 | Philips 60PP9352 60" Rear Projection...
Convergence problem
At present, bad connect(s) on red convergence IC. Soldering pins will fix temporarily.
Usual fix = replace STK392-110  IC's. A 400.00 dollar repair at
your local tv shop......T.
Oct 24, 2007 | Philips 60PP9202 60" Rear Projection...
Phillips 60PP9202 Convergence Problems
The two convergence IC's are generic part# STK392-120 (Philips original part# 932212344682) The two resistors are sitting side by side (6.8 ohm 2 watt)
Sep 15, 2007 | Philips 60PP9202 60" Rear Projection...
Help tv comes on and goes right back off
A common problem with this model is the convergence IC's on the small signal module going bad and keeping the set from staying on due to protective shutdown circuits used. If that is your problem, the easiest fix would be to replace the module - Philips Part #313503710091, about $200 or so, or have a technican replace both IC's Stk392-120, Philips Part #932212344682 about $45.00 each plus labor and service charge of course. Other parts could be bad, but this is likely what I would try first.
Feb 09, 2007 | Philips 43PP9202 43" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
121 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
