Sony KP-57WS510 57 in. Rear Projection HDTV Television
Problem for Sony KP-57WS510 57 in. Rear Projection HDTV Television
Out of focus, double and triple images, I did the
By clubmike2910 on Sep 20, 2009
out of focus, double and triple images, I did the auto convergence, but the manual convergence does not seem to do anything
Best Solution
posted on Sep 20, 2009
Very Helpful)
SD Tech
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 97%, 1155 votes
1.) If the set will not adjust one of the two STK-392-560 convergence chips in this set is bad.
2.) You can buy both chips on Ebay for less than 14 dollars plus shipping.
3.) Usually, just both chips need to be replaced and the set adjusted--sometimes there will be a fuse or resistor that protects the chips bad as well.
4.) If you are able to do this repair yourself you can save a lot of money---Most shops try to charge 300-400 for this kind of repair---I have done hundreds of them and here I charge 200-250 depending on the set.
5.) If you are not able to do this yourself shop around where you live--if they say it has to go to the shop---keep looking as any good tech can do this repair right in your home--usually takes about 1 hour.
6.) The reason this kind of problem happens in all rear projection sets is the chips are mounted on heat sinks to keep them cool(metal with fins) and a white grease(heat sink compound) is applied to the metal back of each chip to quickly transfer heat---after several years from the heat the grease dries out and one of the chips cannot stay cool enough and it fails.
7.) After the chips and any other parts are replaced and the set adjusted--it should not have this problem again for several years.
I do this here for free so if this information has helped you take just a minute to give me a vote here, I am here to help people.
If you have any questions or need advice just reply to this posting here.
REGARDS, SD TECH
Was this helpful?
Yes
No
17 people thought this was helpful
Popular Solutions for Sony KP-57WS510 57 in. Rear
Questions and Unsolved Problems for Sony KP-57WS510 57 in. Rear
Do you recommend Sony KP-57WS510 57 in. Rear Projection HDTV Television?
Answer
Answer
When the set is turned on i can hear the relays engage and thats it red led flashes 6 times
Answer
my kp46wt510 has a red shadow to the right side of any image. Also the convergence mode will not... (More)
Answer
hi, i have a 60 inch projection sony tv, from circa 2000, tv is fine but it seems as though the... (More)
Answer
tv will not come on the red light blinks and you get volume no picture then it shuts off
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in Sedona, AZ
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
