Question about Panasonic KX-T7630 Corded Phone
Answering machine Hi there How to turn off the answering machine.I just want to turn it off so if my phone is busy it will go through another extention.
    Novelist:
  • 201 Answers
Your phone can be programmed to transfer a call to different places and have different rules for day-ring mode and night-ring mode.
Sounds like what you want to do is change your phone to transfer to another extension instead of your voice mail box. This would in effect eliminate your voice mail box because a call would never automatically be sent to it unless you use (and program correctly) night mode.
Your phone model type does not help resolve this. You can have this phone on different Panasonic phone systems. You will need to determine which phone system you have and locate "programming" manual for the specific system (not a user guide)
There should be a section or option called "no-answer forward", "forward timer", "forward extension" etc...
Posted on Dec 14, 2007
How do you forward calls to answering machine for afterhours when business is closed for KXT7633
Put answering machine on a separate telephone number. On the orginal number dial *72 and the number of the answering machine. To return to normal dial *73
Aug 21, 2014 | Panasonic KX-T7736 Corded Phone (KXT7736)
I want to buy the Canon ImageCLASS MF4350d all in one printer. My main concern is receiving faxes. I have a cordless phone with built in answering machine installed in a phone jack downstairs.. the...
No you cannot do it that way. The TAM (Telephone Answering machine) must use the tad port in the machine otherwise the fax will not detect an incoming ring and the fax switch will not function. Your best option would be to put the master phone with the fax and take one of the wireless phones and put that in its place. the cordless does not have to be in the houses master socket. It will work happily on any extension in the house.
Aug 14, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
Hi i have a samsung jey s8000 contract phone however i am unsure how to switch on my voicemail?
hi, if you can't use your voice mail, maybe you can use your answering machine in your jet itself... just configure your answering machine to simply answer all your phone calls, if you are busy.. it will record all callers messages...
it is actually the alternative for your voice mail..
to switch on your voice mail, if you prefer to use the network service. you may try the following steps.. 1. press settings.. 2. on your settings, select applications 3. on your applications, select all calls 4. on your all call settings, select your voice mail and input your voice mail service number.. 5. once finished, select save, and exit your settings menu.. 6. to check if it's working.. use another phone to call your number, but be reminded that if your built in answering machine is on, turn if off..
good luck..
Oct 07, 2010 | Samsung Jet S8000 Cell Phone
I have a VTech Dect 6.0 cordless phone answering machine. I disconnected the power to the answering machine in error. I want to reset the time on the answering machine. How do I do this? My email...
Hi there,From answering your telephonemag-glass_10x10.gif when you are busy or away, to broadcasting a generic message to callers, an answering machine is a key part of your home or office phone system. When the device is working properly, it not only records and playbacks messages, but also informs you of the date and time of the call. If your answering machine is not recording messages, displaying an error code or is presenting another problem, you can reset the device and restore it to a working state.
Aug 03, 2010 | Vtech Digital Cordless Telephone VT-2568
Voicemail is not picking up for incoming calls...
Sounds like you need to set the call forward no answer to the VM pilot DN for the set with the new mailbox.
May 26, 2010 | NorStar Startalk Flash 2 Phone
My Intercom Extention shows busy. I have
With the exception of not being to dial out, it sounds like your DND or do not disturb button is on,The feature can be turned back off by either pressing the DND button again or entering feature #85.
Nov 27, 2009 | NorStar M7310 Corded Phone
Ringer/ Voicemail Bounceback
Well, this one is kinda tricky. If the receptionist knows there's no one there, they can use VoiceMail Transfer.
From the phone, the user can set CF Busy or CF Busy/No Answer with the following codes on the intercom:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding2.gif (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
The last piece of the puzzle is the timing. That's *713 (00-99). Start with 24 (4 rings) and go from there. If it hits the receptionist before the forward takes place, you probably have to adjust the recall timer for call transfer, a system program.
Carl
Aug 11, 2009 | Panasonic KX-T7630 Corded Phone
Disabled phone line
Sounds like the answering machine is picking up the telephone line and not releasing it.
Hence the busy signal, cause the answering machine has the line off hook. It's like leaving your telephone off hook, the next caller will get a busy signal...
The answering machine might be bad... have you noticed that you were talking on the phone and hung up then the next call would be the busy signal? Maybe test this out.
Do you have the correct voltage to the answering machine, too much power or too little power can do funny things to telephone equipement.
May 12, 2009 | AT&T Lands Phones
HOW TO CANCEL A DIVERT FROM ANOTHER EXTENSION NUMBER
no you cannot prevent this from the attendant console.aa is not normally set up.your installer needs to change the class of service of your extension to stop forward no answer. if the other phone/office is unoccupied try leaving it off the hook,your own phone may not want to forward when the other one is busy...i hope this helps
Dec 16, 2008 | Nortel MERIDIAN M2250 ATTENDANT CONSOLE...
Need to connect ans. machine to single line on a multi line business phone. Help!
Out of box, the AT&T 1738 is designed to operate on a single telephone line. I don't know of any device on the market today that could automatically switch it between multiple telephone lines.
Some options include (in no particular order):
1) Purchasing additional 1738s to cover the other telephone lines.
2) Some cordless telephones on the market are designed to handle 2 telephone lines. Their answering machines will cover both lines. AT&T and Panasonic offer such phones.
3) Check out AT&T's line of NoKSU small office telephone sets. The phones will handle up to 4 telephone lines and 1 model features a built in answering machine. In order for the telephones to function 100% all phones would have to be replaced with the models within the AT&T NoKSU family.
4) If this is strictly a business application, consider purchasing a true business telephone system for the office.
Sep 24, 2008 | AT&T 1738 Digital Answering Machine
Panasonic KX-T7630 Corded Phone Logo
289 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
