Question about Sony FD Trinitron WEGA KV-32XBR400 32" TV
XBR450 32" - getting 1080i picture from upscanning DVD Player
How in the world to you know when you have the unit actually putting out a 1080i picture from my upscanning DVD player that says it does this? I use the component cables for the vidoe and RCA cords for the sound, but I am not sure I am getting the 1080i I was hoping for. Does this unit tell you somehow>.
You need 5 RCA cable wire (Red,Green,Blue+Red,White) comb RCA/Cable cords to flow back on the TV connector or review Manul books
Posted on Feb 14, 2008
I know dvd player can not play Blu-ray but is not the Samsung dvd hd870 different. It reads 1080i.
That refers to the video output - your player is capable of upscaling: it transforms, without changing the quality of the image itself, the resolution from SD (480i) to HD (1080i).
Jan 28, 2011 | Samsung DVD-HD850 DVD Player
So you just got your new HDTV and the piture isn't as good as you thought.
There are some things you need to know when setting up your HDTV.
First off, you need to use HDMI cables to connect your tv to your cable box or you will not get HD. That being said the first thing you will find is that HDMI cables are expensive. Although you can buy a really cheapo cheap one, be careful. Make sure it can support 1080p or the max resolution your TV displays at. Some of the cheaper ones can only support up to 720p.
So you hooked it up to the cable box using an good HDMI cable and you still do not have the picture you should. There are a few things you may still need too do to get 1080i out of it. Yes, I said 1080i. Even though your tv may be up too 1080p, cable and dish networks only transmit up too 1080i. But don't worry, 1080i is amazing for cable/dish.
First thing you need to make sure of is, does your cable/dish receiver support HD? If you have had the same box for a long time, it may not. You will have to call your provider to get an updated box. If you recently got cable/dish and the box is new, most likely your good to go. Also, it will most likely say on it, HDTV, 1080i or something related to HD on it.
Now you are good to go with you box because it is in fact HD compatible. Some cable boxes may need to be configured for HD. You don't need an HDTV signal if you don't have an HDTV, and not every one does, so why send the unit configured for HD. You need to go into your cable/dish settings and make sure you set the HD set up to display in 1080i.
Okay you set the box to 1080i. There still could be some setting on the TV if your not getting the best picture.
Make sure you are on an HD channel. Make sure you do not have zoom on, and that the TV is set to display an aspect ratio that is determined by the program, or auto. Not all TV's have these settings. Likewise, some tv's allow you to select the max resolution, if this is the case make sure it is set to 1080p, the max it can be.
You should at this point have an excellent picture on the HD channels. Not all channels are HD.
Now, a few other things not worthy as a new owner of an HDTV.
a standard dvd player does not play in high def. they have a max resolution of 480p. 480p is going to look really good if its the first time you watch a dvd on an HDTV, but it can be a lot better. For around starting at $45 and up, you can buy a DVD player that can upscale your dvd's to 1080p when you use HDMI and you will get amazing picture. But for around starting at anywhere from $100 to $150 and up, you can get your self a blu-ray player that will play blu-ray disks, and give you amazing beyond belief picture, and it will upscale your dvd's.
So you got a blu-ray. First thing I can say is I hope your refresh rate is at least 120hz or better. 60hz may disappoint you with a blu-ray player.
Blu-ray can play movies in their native 24 frames a second format of which they were filmed in. However, at 60hz, you will run into a problem trying to play the movie in 24fs. now I am not going to get technical with this, just to let you know, you need 120hz or better to use 24fs. You can turn it off, but you will get blur and it will not be as smooth. As well, with most players you must enable 24fs in the settings, usually by default, it is off,
So to recap:
  • Make sure your cab/dish box is HD compatible.
  • Always use HDMI cables.
  • Check settings on cable/dish box and make sure its set to 1080i.
  • don't use zoom.
  • If applicable, make sure tv settings are at max res of 1080i
  • you need an upscaling DVD player or Blu-ray player to watch your DVD's in HD.
  • Also must us HDMI.
  • Can't use 24fs if you have 60hz refresh rate, but can if 120 or better.
  • 24s is usually off by default.
on Mar 06, 2010 | Televison & Video
How does a blu-ray movie look on a 720p TV?
It will look great. You can actually set it for 1080i. I have an older model HDTV(no HDMI) and a bluray player it looks great. TVs that are 720p will actually do 1080i. The only difference is 1080i is two pictures interlaced(the way tv has always been before digital) and 1080p is one single shot. If this helps please rate me. I do not get paid for this but I like helping people.
Dec 17, 2010 | Televison & Video
How do i set video from 480i to 1080i??
when your using the comp in or hdmi the tv should swithch automaticlly but you must have an HD signal
Nov 30, 2009 | Mitsubishi WS-65615 65" TV
Cant figure out to hook up keeps saying no signal with hdmi cable to tv and blu ray put in
What kind of TV are you hooking the dvd player up to ? You may have to go into the TVs menu and set the input to the proper resolution or input style to see a picture. The dvd outputs a 1080i and if the TV is set to 720p it may not show a picture, the dvd output can also be changed to match the TV.
Sep 06, 2009 | Samsung BD-P2500 Blu-Ray Player
Dvd player stuck in progressive mode
ok i got a solutioN!!!
ok go to ur actual dvd/vcr player (not the remote) and press and hole the STOP botton for like 5-10 seconds.
thank goodnesss!!!!!!!!!!!!
your welcome! :]]
Jun 11, 2008 | Zenith XBV243 DVD Player/VCR
Red Screen
i have the Toshiba A1 and a benQ W9000 projector. I never had this problem with my Sony HS60. I switched the video from 1080i to 720p and then back to 1080i and it fixed it immediately .... its really annoying though
Dec 30, 2007 | Toshiba HD-A30 HD-DVD Player
Toshiba dvd setting
1. You would press and hold stop on the front of the unit for 5 seconds then let go and press it again normally, you can try this with both the power of the unit on and off.
Sep 20, 2007 | Televison & Video
No HD 1080i
have you got the slider switch at high definition and not TV at the connecting end at the xbox that leads to the tv input
May 21, 2007 | Mitsubishi WS-73411 73" Rear Projection...
Sony FD Trinitron WEGA KV-32XBR400 32" TV Logo
69 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
