Question about Samsung HLR5067WX 50" Rear Projection HDTV
HELP HL-R5067W LOUD GRINDING/VIBRATING NOISE
I have a samsung HL-R5067W and it is making a LOUD GRINDING/VIBRATING NOISE. The color is distorted and fades in and out.
  • 1 more comment
  • Gumbo428 Dec 16, 2007
    Heard a pop, then a frozen yellow tented picture, now I can't get any picture. The weird thing is that when I try to turn it off with the power button, nothing happens. I have to unplug it. It makes a fan belt buzzing type noise too.
  • dababneh Jan 20, 2008
    I am having the same problem on the exact same model. I have looked around online but I can't quite figure out if I need to do something with the internal fan or if this is the color wheel problem.Any advise would be greatly appreciated.
  • Anonymous Mar 23, 2014
    is making a loud blowing fan like noise
    is that a broken fan and can it be replaced
    Sergeant:
    Champion:
  • 231 Answers
Noise you are hearing can be the fans inside with bad bearings and or what im assuming given the info you gave.More likely the motor inside the optics engine (color wheel) is making noise..This will also cause picture problems..very expensive to repair..
Posted on Dec 14, 2007
Buzzing noise in my HL-R5067W
you might be right. Color wheel can make this noise.
Jun 08, 2012 | Samsung DLP HL-P5663W 56" TV
I have Samsung DLP TV 50 inch HL-P5063W
First thing to look at is the color wheel this model uses--usually it will make a high pitched fan like sound but can make a grinding sound also.
If it slows down from the 12,000 or so RPM speed it will cause color issues.
HAVE GRINDING OR HIGH PITCHED SOUND?
Apr 02, 2012 | Samsung Televison & Video
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
I have a samsung HL R5067W DLP TV. the fan makes loud noise and runs eradically (spins up and spins down) any suggestions? Is fan bad?
Hi, have you removed rear covers and verified it`s one of the fans ? Those sets are notorious for loud color wheels, we have replaced 2-3 fans but we`ve replaced 50 color wheels, light engine has to be pulled to replace cw so call and get an estimate first so you can verify which has failed but my moneys on the color wheel, good luck, video-tek
Jul 01, 2009 | Samsung Televison & Video
Loud humming and color is distorted
You most likely need to have the color wheel replaced,its a common problem with the samsung DLP sets.
Apr 29, 2009 | Samsung DLP HL-P5663W 56" TV
HL-P5063W vibrating and won't turn on
i have had this happen to me several times in the field, and if it is what i think it is, you are not going to be happy =(
inside of a DLP type TV, there is a device called a 'color wheel'... it is essentially a disc made up of different colored glass that spins really fast. this disc has 3 or 6 (depending on make/model) pieces of colored glass like pieces of a pie affixed (read: glued) to a hub.
what happens sometimes is that one of the pieces of colored glass flys out of the hub, and causes a massive unbalance in the spinning wheel, which causes the hum/vibration, and since the colored glass is missing, the colors will be all messed up.
if this is what happened, then your television will require a new DLP engine.
Dec 08, 2008 | Televison & Video
Samsung HL-R5067W
defective color wheel needs service
Sep 09, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HLR5067WX 50" Rear Projection HDTV Logo
381 people viewed this question
Jerry Greenberg
Jerry Greenberg
