I want sum these times correctly, so it looks like this: 00:01:10. It works fine when I do A1+A2+A3.
But when I use the SUM(A1:A3) command, the results are always 00:00:00. This happens no matter how I change the format (i.e. I have changed the results cell to General, TIME, or hh:mm:ss or [h]:mm:ss; and the data cells similarly).
Using a time format for the data cells and data that looks like 12:00:10 AM the result you want is displayed no matter which formula is used. If the date portion of the data cell is not deleted then the result is 00:00:00. Delete the date portion of your data cells to get the result you want. (For example: When I enter 10 into a cell that is formated for time xx:xx:xx it shows 1/11/1904 12:00:00 AM in the formula bar and 00:00:00 in the cell. When I delete 1/11/1904 in the formula bar and show only the 12:00:10 the cell shows 00:00:10. Then it makes no difference which formula you use.)
i have made the entries correctly, but the total is wrong. pl help, even after deleting and entering...
(More)
i have made the entries correctly, but the total is wrong. pl help, even after deleting and entering again for the same month, the problem persists(this problem is only for a certain month, others are correct)
i want to take features off of my ms office 2003, but it won't because a file PA561401.CAB is...
(More)
i want to take features off of my ms office 2003, but it won't because a file PA561401.CAB is missing. where can i find this missing file? or is there a way to uninstall everything except for 2003 ms word?
How to write script in VBA which helps to creat a macros in excel. As if now i dont know what is VBA...
(More)
How to write script in VBA which helps to creat a macros in excel. As if now i dont know what is VBA and Macros and how it works. Can you please help out with this regard.
When attempting to view pictures i keep getting the following mesaage: The selected location does...
(More)
When attempting to view pictures i keep getting the following mesaage: The selected location does not contain pictures to preview, but other files exist. To view these files, on the View menu click Show Pictures Only. However, having tried this, I'm still unable to view any pictures!
If the total percentage of x is between 85%-100% then the value should be 5, if the total percentage...
(More)
If the total percentage of x is between 85%-100% then the value should be 5, if the total percentage of x is between 75%-85% then the value should be 4, same for 3,2 & 1.If someone can help I apprecioate it.
