Back to:
Tags:
Raymarine ST60 Plus Wind System Analog Vane A22012-P by GPS Receiver
St60 wind instrument (by 3 users)
posted by aristelo on Dec 13, 2007
we are having problem with st60 wind display,the wind speed is not functioning(brand new)
the apparent wind reading is always zero,the analog pointer works and tell the direction of the wind but no apparent wind speed is shown
we check the wire from the transducer up to the back of the display as follow
used shield as reference
blue= 4.2 vdc
green= 3.0 vdc
yellow=7.8 vdc
red= 8 vdc
as we know the yellow wire is for the wind speed signal and varrying.....
pls tell us what is the problem with the display its brand new and are we missing something?
firmware version is 7.03
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Glenn54, posted on Aug 22, 2008
I've recently installed the st60 wind instrument. It only displays the 3 dashes, no wind speed and no anolog display. I've bnen into intermediate calibration and it shows 7.05 and r1 meaning it's a repeater, but it is the Master. I've gone into the dealer calibration and switched to factory settings but this does not save after exiting even after holding down Disp and App/True.
Anyone know how to change the r1 Repeater setting to r0 Master setting?
Comment by schooner19, posted on Jul 27, 2008
Just installed st60 vane. The sensor (vane) has been installed for ~ 1yr and just got the instruments installed and powered. 3 instruments, depth, speed, wind. Depth works fine, speed is probably fouled. Vane analog display works, digital wind speed does not. haven't checked voltage from sensor as sensor is up mast and out of reach. What would be the best way to proceed?
Best Solution
posted on Dec 28, 2007
Helpful (85)
capnsunshine
Rank:Master Master
Rating: 88%, 17 votes
You might want to double check that all of the spade connectors that are used to plug the wind transducer into the ST60 wind display are firmly plugged onto the display's terminals.
Because of the blind connection, sometimes the terminal ends up lodged between the red insulator and the spade, rather than within the spade connector itself. This results in intermittent or missing readings from one part of the sensor or more.
Also make sure the display is in Master mode. You will need to get into its setup mode to confirm this. The other possible mode is repeater, which would be used if this were a secondary readout.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on st60 wind instrument:
I don't want to Accept this solution
Can you Help with these GPS Devices problems?
GPS Devices
gps wont come on
GPS Devices
garmin chartplotter gps on our boat froze-message says...
Raymarine ST60 Plus Wind System Analog Vane...
Trouble calibrating Marine ST40 wind instrument
Raymarine autohelm 1000 Raymaine remote control...
Hi. I have a boat with an ST60 instrument, was working...
Loading problems.
Repair Service
Find GPS Device Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
