Question about Efficient Networks SpeedStream 5200 Modem
Speedstream 5200 IE browswer will display error- i checked router/s: okay, i re-installed xp on 2 different pc's: okay, ihooked dsl modem directlt to main pc and still same problem, could my modem be going bad-it's over 2 yrs. old?
Your dsn is incorrect
Posted on May 05, 2008
How do i acces my modem to get it out of bridge mode to use it without a router
Hi paintballa12!
Here's the link for yor modem's userguide..
http://www2.windstream.net/downloads/links/SpeedStream211.pdf
Normally, all dsl modems can be "unbridged" byr resetting it to factory state.. But that would mean you have to save you DSL username & password again..
Check page 38 for setting modem to non-bridge mode..
Hope this helps..
Mar 10, 2011 | Efficient Networks SpeedStream 5200 Modem
Does the speedstream 5200 offer wireless capability?
No it do not ahev wireless feature. details fo this devices are:-
Manufacturer: Efficient Networks Product MPN MPN 33A-5200-701 Key Features Router Functionalities dtrquestion.gif Firewall • DHCP Server Connectivity Wired Interfaces LAN Interfaces 10/100 Base-T WAN Interfaces dtrquestion.gif ATM Additional Interfaces 1 x USB Standards and Protocols LAN Standards IEEE 802.3 CSMA/CD or Ethernet • IEEE 802.3u 100 Mbps (Fast Ethernet) Protocols dtrquestion.gif ATM • DHCP • IP • PPPoA • PPPoE • TCP Routing Protocols RIP Version 1 • RIP Version 2 • Static Routing Remote Management Protocol dtrquestion.gif HTTP • Telnet • SNMP 1 Firewall / VPN Firewall Features Stateful Packet Inspection (SPI) • DoS Prevention • NAT Authentication PAP (UPAP) • CHAP Modem DSL Standards ADSL Lite (G.Lite ITU G.992.2) • ADSL Full Rate (G.DMT ITU G.992.1) Other Features LED Indicators Power • WAN • Activity • DSL Additional Features Auto Crossover (MDI/MDI-X) Warranty Warranty 1 Year Miscellaneous Release Date 2003
May 01, 2010 | Efficient Networks SpeedStream 5200 Modem
No internet connection
This should be connected as so. From wall outlet to DSL modem, from DSL modem to D-Link router, From D-Link router to Laptop via wireless or wired connection. You will still need the DSL modem installed but the wire coming from the DSL modem will go to uplink port on the router instead of into the laptop.
Dec 21, 2008 | Computers & Internet
Speedstream 4100 does not work with router
you can't.
when the item name as modem/router. it means the main function is modem with added router function.
you can't connect 2 router/modem together. both need access to the internet and IPS for it function correctly.
however, you can connect 1 modem and one router.
Oct 19, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
I have a new modem: model speedstream 5200, now I can't connect my router: Linskeys model BEFSR41
Your router and DSL modem probably both are set to the same IP address:
192.168.1.1
Change one of them to 192.168.1.2(I'm suggesting the Linksys)
and it should fix the problem and have them both working again.
May 01, 2008 | Computers & Internet
Speedstream 5200 modem
Open the following link --
speedstream 5200
Download the manual from the link and review page 7 for ethernet connection.
Notice particularly the back of the device. There are four connection points to plug things in the one on the left with DSL is where cable with the phone connectors connects the phone jack to the speedstream 5200. On the right the round connector with the pin is where the power goes. Next to the power connector to the left is a USB connector. In between usb connector and the DSL port is an ethernet connector. One way to avoid the need for the USB software os to use the ethernet connector bu connecting an ethenet cable (wider connector that fits snugly in both ports one on the Speadstream 5200 and the other probably present on your computer.
USB driver including VISTA (if you prefer)
USB driver link
Dec 11, 2007 | Efficient Networks SpeedStream 5200 Modem
Speedstream 5200
here is the pdf download link for this modem
should be of some use
Oct 10, 2007 | Efficient Networks SpeedStream 5200 Modem
Speedstream modem 4200
put the modem in bridge mode and then connect a DSL/cable router to it...you'll have to configure the PPOE if its DSL... Cable is a little easier because there usually is a MAC authientication not username and password...plug dsl/cable router into cable modem...turn both off for about aminute then turn modem on first then router... Be careful most routers with wireless have it enable with no security by default...turn it off or set securty (wirelss that is)
Aug 27, 2007 | Siemens SpeedStream 4200 (13A4200001)...
ISP SBC SpeedStream 5100b Modem Causes Install and Connection to Fail
Symptoms * You have a new router, and cannot get online to the Internet. AND * The Setupwizard will detect dynamic IP even though you have a PPoE connection. (Going to router status on the administration page, there is a private IP address on Internet port. 192.168.x.x range.) Cause The SBC DSL modem SpeedStream 5100b, used on new DSL and Yahoo SBC DSL installations since Feb. 2004, causes the NETGEAR router Setup Wizards to fail, and prevents routers from connecting to the Internet. This problem affects many router brands. The modem can be distinguished from the earlier 5100 by a 5th light labeled "Internet". The SpeedStream 5100b's default configuration is "PPPoE on the Modem" ? matching a built-in PPPoE client convenience feature that sends login ID and password to SBC. To Work Around These Issues, Configure the Modem for Bridged Mode Note: In Bridge Mode you cannot to connect to the modem's configuration menu, except by resetting it as described below. 1. Disconnect the router from your network, and connect the computer directly to the SpeedStream modem 2. Open an Internet browser. 3. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 4. Click Advanced. 5. Enter the "Access Code" printed on the bottom of the modem. 6. Click PPP Location. The PPP Location screen appears. 7. Select Bridged Mode (PPPoE is Not Used). 8. Click Save Changes. 9. Connect the router between the computer and the modem. 10. Power off the modem. 11. Power off the computer. 12. Connect the Internet port of the NETGEAR router to the Ethernet port of the modem. 13. Connect the computer to a LAN port on the NETGEAR router. 14. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 15. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 16. Power on the computer. 17. Log in to the router by typing 192.168.0.1 in your browser. 18. When prompted, using lowercase letters, type admin for the user name, and password for the password. Some older routers use 1234 for the default password. If you forgot your router password see http://www.fixya.com/ThreadView.aspx?thid=102081&prdid=252188 19. Use the Setup Wizard to connect to the Internet. To Reset the Modem To Enable Access to the Configuration Screen 1. Disconnect the computer from the modem. 2. Power off the modem. 3. Power off the computer. 4. Connect the Ethernet port of the modem to the computer Ethernet port. 5. Power on the modem and wait for 2 minutes. Don't go to the next step until this is finished. 6. Power on the router and wait for 1 minute. Don't go to the next step until this is finished. 7. Power on the computer. 8. Open an Internet browser. 9. Type 192.168.0.1 in the browser address field and click Enter. The modem displays a configuration menu. 10. Click Advanced. 11. Enter the "Access Code" printed on the bottom of the modem. 12. Click PPP Location. The PPP Location screen appears. 13. Select PPPoE on the modem. 14. Click Save Changes. 15. At the login screen type in your SBC member ID and password (which is usually the primary email address on the SBC DSL account and the password for the primary email address). 16. Click Connect. * If successful, a screen appears reading "You Are Connected", and the Internet light goes solid green. * An error will display if the username or password is invalid. * If there are other problems the message "The DSL connection is down" appears.
Feb 19, 2006 | NetGear FR114P Router
Efficient Networks SpeedStream 5200 Modem Logo
322 people viewed this question
Top Efficient Networks Computers & Internet Experts
Vijay Damaraju
Vijay Damaraju
Level 1 Expert
Michael Galve
Michael Galve
Jax Planet
Jax Planet
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
