Question about Nokia 1600 Cellular Phone
Motorola V3m Key Pad is not working. One minute it was and the next it was not. I can only press certain buttons. It also thinks that it is trying to unlock my phone (because it locked when it stop working) so while its doing that I keep getting error codes back to back saying, invalid lock code please re-enter and it is happening over and over again. Is there a solution for this? This did happen to me before and eventually got it to work just by leaving it alone but that only lasted a half hour. Please help.
  • radioshack01 Jan 02, 2008
    i have the same problem i changed my key pad lock code and now i carnt get in 2 my phone at all please can some 1 help
My Thuraya Hughes keeps coming up with an error code CC38 does anyone know what that is???
Posted on Mar 27, 2008
  • Nomad
    Nomad Jun 26, 2011
    You sat phone can't see the satellite in the sky properly. It does receive the signal but can't talk back. Move around and try again
I have a motorola razr3m and I want to erase all info from memory
Press and hold the Green dial button, Star button, and the no. 3 button. Then press the power or on/off to button on the phone. Do not let go of the green, *, 3 buttons until you see a formatting screen. After a few minutes formatting will be complete and your phone will be back to factory settings. Hope this helps.
Dec 31, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Press any button and phone does nothing
take the battery out without switching it off and put it back again it will work fine.even i used to have the same problem.after doing this back up everything and reset your phone you wont have the problem again.
Jul 14, 2009 | Motorola Mobility RAZR V3m Cellular Phone
How to change time on my T7316E Nortel phone
Step 1
Press the FEATURE key followed by **8463
Password Retry Step 2
Press 266344 on the dial pad buttons to enter the DEFAULT password. Your password MAY BE DIFFERENT! The display will show the following options:
Hour: 01 Next Change Step 3
Select CHANGE - the display will show the following options:
Hour: __ Cancl Step 4
Use the dial pad buttons to enter the hour. You must use two digits for all hours (i.e. "08" for 8 o'clock). You will be prompted to enter AM or PM. Select CHANGE and OK to choose PM. AM OK Change Step 5
After you have entered the hours, select NEXT. The display will show minutes as 00. Use the dial pad buttons to enter the minutes. If you are just changing the time, press the RELEASE (RLS) button to end your session. The time will be changed and the date will remain the same.
If you want to change the date, select NEXT.
Minutes: 00 Next Change Step 6
The display will show 99 as the year. Using two digits, enter the year using the dial pad buttons (i.e. "05" for 2005).
Select NEXT, and repeat to change the month and the day.
Year: 99 Next Change Step 7
Once you have entered the day, press the RELEASE (RLS) key to end your session. This will save the changed time and date.
Mar 11, 2009 | Lands Phones
Master Reset
the OPCODe can master reset the phone. I screwed up my phone by trying to change the theme and evry time i pressed menu the phone restarted. However, i found a post on another site that read...
For me, Motokit, PTS, and the reset of the tools could not reset my phone. Here's how I reset my phone with just the phone keboard.
This will reset all your menus. On my Verizon Razr V3m phone, my contact and my picture gallery were not affected. (Make sure you key the command in exactly. 18*1 is Master Clear, and you don't want do to that.
From your phone, enter this sequence to go into OPCODE mode fairly quickly:
Press CLR then
048263*
This puts you in OPCODE mode, where you can enter special commands. Be CAREFUL here.
Enter a the code for a Master Reset command:
18*0
Press the middle navigation button.
Wait. The screen should show "SUCCESS" after a few seconds.
Push the LEFT soft key (back). You'll be back at the OPCODE screen.
Push the RIGHT soft key (options). Push this button again to select Cancel Entry (the only option).
This gets you out of OPCODE and back to where you started. You might have to push CLR a few times to clear the number you entered to get into OPCODE mode.
It was really helpful
Aug 16, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola V3M booting problems
try changing the battery.....if that does not work you may need to take the phone to a mobile repair cnter and have them service the main-board
May 20, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Backlight display not working
Hey Dannes1956,
The Motorola V3m has a light sensor, which is visible just above the right soft key -- the key above the CLR button. This light sensor turns the backlight on when you press a key in the dark and disables the keypad backlight when you are in a well-lit area.
Your phone sounds like it's operating normally. I believe they disabled the option to activate or deactivate that feature.
Hope this helps,
cHiPz.
Mar 17, 2008 | Motorola Mobility RAZR V3
Motorola BR 50
well you have to get the mobile service.......take it to a mobile service center and have it service there
Jan 31, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Razr V3M Power-up/Black Screen
I ended up having to take my phone back to Verizon.  They replaced it with a brand new one because they were unable to find the problem.
Oct 16, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Nokia 1600 Cellular Phone Logo
563 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
