Question about JVC MX-D761T Shelf System
CD players, All sound
I have mulitiple problems with my MX-D761T system:
First off when a CD is inserted into any of the tracks it will not play. The motor will spin as if its going to play and then it says no disc. Have used multiple discs in all of the 3 tables same outcome each time.
Also I can not get any sound out of the system. I have even tried using a set of headphones plugged into the front of the system to see if I was connected improperly or if it was faulty wiring or wires. No avail. Not really sure whats going on with it. Any help would be appreciated. Thanks in advance.
SOURCE: Disc Player not working
Please notify me when, and if, there is a solution. Thanks
Posted on Dec 07, 2007
  • 319 Answers
SOURCE: Error message No Disc
Unit has bad disk t-table motor
Posted on May 07, 2008
VOTIT
  • 2071 Answers
SOURCE: CD Player Problems
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 17, 2008
fkuk
  • 311 Answers
SOURCE: JVC mx-d761t fuse
are you talking about the internal fuse? or the fuse in the plug
im assuming that you are talking about the internal fuse
get a standard glass tube fuse at the amperage you know about
i belive it does not matter what type of fuse it is as long as the diamentions are the same its good
Posted on May 12, 2010
AJIN G
  • 6694 Answers
SOURCE: JVC /MX-D761T/ compact component system> The
hi,
Is there is power in your system. is there is any power indication.if not then you have to check the Powre transformer, its fuse, and the small standby transformer near the power transformer. If the stanby transformer is faulty then there will no power indication in your system.
If there is power and the cd is not reading then, You have to check the laser pickup unit inside your system. First of all purchase a laser cleaning cd and insert the same in to your system. If will clean the laser pickup unit to some extent. if then also it is not reading any cd then the laser pickup is faulty. As it has a changer mechanisum it will be difficult to you to replace the lase pickup unit.Because you have to remove so many parts from the mechanisum to reach to the laser pickup unit. If so try to consult some one experienced in it.
ok
Posted on Jul 30, 2011
Display demo
Could it have been knocked when in storage? Also try cleaning the lens of the CD player see if that makes a difference.
Jul 23, 2013 | JVC MX-K30 CD Shelf System
JVC mx-d761t fuse
May 11, 2010 | JVC MX-D761T Shelf System
I have a JVC MX-D761T stereo and the cd's are dusty and dirty. bought a DYNEX laser lens cleaner but without it working the cleaner cannot clean. any suggestions on how to start cd's so that the laser...
Yea I have the sam system...its great! My laser got old as well. I looked up on line and ordered a $40 new reader...put it in myself..piece of cake. It won't read or spin cause it can't see. You can make sure it has power to it, but most likely like mine it has burnt out.
try that
Sep 18, 2009 | JVC MX-D761T Shelf System
Makes a buzzing/humming sound when playing a dvd or cd
that is a problem with the amp.
does this player have a dvd player built in or not
May 11, 2009 | Televison & Video
Burning DVD from Windows movie maker and audio is funky!
after copleting save it in u r system as .dat format.
then use nero n select make video dvd
ur's kishore
for more help catch me on +919985064600
+919963674002
friends_kishore@yahoo.co.in
Feb 10, 2009 | Roxio Easy CD & DVD Burning
CD player does not work
10/6/08 Update.
Solved the problem myself.
Repositioned the printed circuit board with the CD Drawer open/close limit switch.
I suspect that the board shifted during shipping and failed to trigger the closed drawer position.
Player is now working.
Sep 27, 2008 | Emerson NR303TT CD Shelf System
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Disc won't play
Silmilar problem on a MX-D501T
At times the unit fails to recognise the music CD in the tray, or recognises its presence and shows tracks & time play on screen but doesn't initiate playing. The fault is erratic. Pushing 'play' on the remote doesn't initiate either.
Is this a faulty head or 'dry joints' somwhere?
Dec 09, 2007 | JVC MX-D301T Shelf System
NAD 5000 CD player
I FIX MY NAD 5000 CLEANING THE LASER LENS USING COMPRESS AIR
Nov 06, 2007 | Audio Players & Recorders
JVC MX-D761T Shelf System Logo
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
