@littlemike: That radio does not have an auxiliary input. If you want to keep that radio, the only way to input satellite would be to use an FM modulated device that transmits the signal via your FM tuner.@littlemike: That radio does not have an auxiliary input. If you want to keep that radio, the only way to input satellite would be to use an FM modulated device that transmits the signal via your FM tuner.
You can't post conmments that contain an email address.
Thi JVC KD-G200 does not have an auxiliary input, or aux mode. If you want to play audio from an external device through this unit, you will need a FM transceiver.
Check to make sure the antenna wire is attached to the back of the radio. Also there should be a source button that switches to 3 different preset settings. Try using this. If there is still a problem, let me know.
Have you checked the fuse-box to make sure that you didn't blow the fuse for the radio? Also try removing the radio and checking the wiring to ensure that it is tight. There is also a fuse on the back of most radios to check!!
