Question about Hotpoint Aquarius WF000 Front Load Washer
Water will not empty
The water does not empty from machine after it spins
  • Anonymous Feb 29, 2008
    My Hotpoint WF000 now leaves water in the drum. After emptying out clothes, it will empty when I select 'pump out', so can I assume its not the pump?
    We are in a very hard water area, and I'm wondering if that has anything to do with it?
An elastic band wrapped round the blades in the pump was the solution to our machine
Posted on Feb 09, 2008
    Champion:
  • 249 Answers
There must be something caught in the pump,remove drawer,lay machine down on its side,check bottom hose from drum to filter,look for ,sock,or hankie,etc,then check pump out,remove it If you have to! look for small objects that might be caught in the empeller,let me know how you got on,Close eire
Posted on Dec 14, 2007
  • 139 Answers
Hello
you either have a blockage in the filter or you pump is not working.
how to check is diconnect the waste pipe and lower it to ground level if the water does not empty then its a blockage. if it empties then its the pump.
other things it can be is a blockage where the waste pipe is connected or a loose wire to the pump..
Posted on Dec 13, 2007
3 Suggested Answers
  • 175 Answers
SOURCE: machine will not drain water or spin
hi..Most washing machine have a drain filter that can become
clogged over time.Front load washers typically have a small
removable panel about the size of a half sheet of paper on the
bottom front of the machine.the filter is inside.
check it out..
thank u..
kindly rate my response..
Posted on May 09, 2009
  • 207 Answers
SOURCE: will not empty water
sounds like ur pump is getting weak and going out it will have to be replaced
Posted on Feb 25, 2010
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
I can hear water in washing machine when I spin the empty tub
The balance ring has liquid in it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 09, 2012 | Washing Machines
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
Intuitive eco
this machine will not spin until it is empty of water. it sounds like your pump is jammed. first- empty water by hand then tip machine backwards so you can look underneath. only tip it back enough to look underneath. on the front right of the machine you will see a black or red fan, that is the pump. turn the fan clockwise then anti clockwise and hopefully that will loosen up what is jamming the pump. put the machine back on its feet and turn it on. advance cycle to spin then push start. it should start draining the rest of the water out and start spinning. please reply 4 more help
May 21, 2010 | Fisher and Paykel (IWL12)
Water not emptying from the machine,
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Ariston Technologies Ariston AWD12 Front...
Wont spin
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Feb 02, 2010 | Washing Machines
Bosch wff 1401 not emptying water therfor not able to spin the pump goes round but water does not empty if i drain the water the machine will spin
If you have not already done so, then check and clean filter located at bottom front right of washer behind drop down cover.
If it still does not empty, then it is either blocked between the pump and tge waste outlet, or the pump itself could be faulty.
Jan 25, 2010 | Bosch Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Hotpoint Aquarius WF000 Front Load Washer Logo
207 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
