Question about Sharp 27C-240 27" TV
DVD ejection I have a 27" sharp TV with VCR & DVD as part of the unit. I put in a DVD and now I can not get the DVD to play and can not get the DVD to eject. Is there a trick or a quick release for the DVD tray so I can get the DVD out?????
  • larry y Dec 27, 2007
    I looked originally for a hole for a paper clip, and I just looked again. I could not find the hole. However, the other solution worked for me. It was to "unplug" the TV for a 5 seconds. The DVD player works fine now.
  • 149 Answers
Hi there, there is a small hole at the front pannel of the DVD player, use paper clips to push the eject manualy and pressing eject botton at the same time. ty
Posted on Dec 24, 2007
THE DVD WON'T OPEN OR PLAY ON MY TOSHIBA TV/VCR/DVD COMBO MW27FN1
check either the front or back of television for a small pinhole, that should be the emergency eject hole, place unwound paper clip in hole to eject disk, however, this will probably be re-occuring and dvd player will need to be replaced.
Oct 17, 2010 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Sylvanis tv vcr dvd combo
It sounds like the VCR mode switch is dirty. This is located on the PCB, underneath the right hand side of the VCR mechanism. If you do not know what you are doing, I do not recommend trying to clean it yourself. You have to remove the VCR from the board, and pop the wheel off the top of the switch. Use a cotton swab with a bit of alcohol to clean it, and then put a dab of WD-40 on it. Good luck. Also, you might want to tryt to reset the VCR mechanism to the fully ejected position if it is not there already.
Sep 05, 2008 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
TV/DVD/Cd Combo
Greetings Kadzgram,
If the unit is not functioning I would advise contacting the retail establishment you purchased the unit from and seeing if you are still able to exchange the unit. If you are unable to, the unit should have a manufacturers warranty which should cover it. I would also suggest possibly contacting Sharp through the following site: http://www.sharpusa.com/global/ContactUsSharpDirect/
I hope this helps!
Thank you,
Dorothy
Go Ahead. Use Us.
Jul 22, 2008 | Televison & Video
Panasonic PV-D4743S combo DVD/VCR player won't eject DVD
This unit has seperate power supplies for the DVD and VCR side and the DVD side supply seems prone to failure. I have not isolated the cause, but can tell you this will require a component level repair. Unless you are a tech you may as well buy a new unit.
Sep 22, 2007 | Panasonic PV-DM2794 27 in. TV/VCR/DVD...
Dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
Sep 14, 2007 | Panasonic PV-DM2792 Triple Play 27 in....
Unable to open my DVD player
i have same problem with vcr , all mecahnism ok but dvd ok but vcr does not work all mechanism ok beccause i check manul its and are ok let me know if you knw somethins , in your case chech manual it open the dvd internal and check for work manual . wilfred
May 27, 2007 | Panasonic PV-DR2714 27 in. TV/VCR/DVR...
DVD went in...and won't come out
Whatever you do, DON'T try ejecting it manually. it can ruin the dvd mechanism. The problem is in the dvd power supply. If you have some soldering skills and are good with a soldering iron(temperature controlled is best) you can resolder all the three-legged regulators on the dvd power supply board(small board to the right front of chassis). Good success, Meder's Tv
Feb 20, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
DVD will not eject DVD
I just had that same problem. i tried turning the tv off and then but didn't work. What worked for me was tu unplugged the power chord from the outlet, wait for 5 seconds, then replugged it, turn the tv on and while it's turning on open the dvd tray. It should open without problem. At least it worked for me.
Dec 26, 2006 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Sharp 27C-240 27" TV Logo
171 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
