Need help with new hard drive
I bought a new simpletech 320gb hi-speed usb 2.0 external hard drive and also a 2-port usb 2.0 pci card and installed them on my pc. After installing i went to systems and device manager and it showed they were installed and working properly but i am not able to transfer things from my local disk:c and also i am getting a symble in my task bar saying to safely remove hardware from my computer
  • 121 Answers
Try formating it bye right clicking on it unlikely but might work
Posted on Mar 03, 2008
For the last couple of months I've had to un-plug, then re-plug my EHD to get it to be recognized by my HP laptop. Today my HP says that the device is not regonized. Can the Signature Mini be re
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Hope this helps.
Jan 24, 2013 | SimpleTech Signature Mini 250GB External...
When i plug in the usb to my computer it is not recognized and does not show anywher
b>
Dec 14, 2012 | SimpleTech 500GB SimpleDrive Pro External...
Won't recognize external hd
Dec 11, 2012 | SimpleTech SimpleDrive Pininfarina 500GB...
Computer is not recognizing
If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing. Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
hope this helps
Oct 15, 2012 | SimpleTech SimpleDrive Pininfarina 320GB...
I need a manual for the black cherry portable high-speed UB 2.0 hard drive. The one I have is 160 GB. Thanks.
Here is the manual that covers all of the SimpleTech Signature Mini External USB 2.0 Hard Drives. This is a pdf document, so you may need to install Adobe Acrobat Reader if you don't already have it installed.
Hard Drive Manual
Regards,
Dan
Mar 05, 2011 | SimpleTech Signature Mini 320GB External...
My hard drive copying and pasting is very slow.For 500-700 mb files it takes more than 25 minutes....what should i do to increase the speed?
Im only guessing that its an older PC and your USB connection is probably USB 1? If this is so you can install a PCI USB 2.0 internal card which normally gives you 4 ports which is about 20 times faster. Cheers from Scott and please vote ........bout $10 - $15 at most i think at any good PC shop
Feb 08, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
My SimpleTech 320GB external hard drive is no longer recognized
trying using it on another system and and see if it happens like that. if it does, you may want to get a driver for the hard drive. it is likely the driver is corrupted. try it on another port also.
Jun 09, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
A website to download a new install disk ...
I believe the simpletech you have is a plug and play, you should not need a driver to access it.
May 23, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Opening simpletech download onto Acer with Vista
hard drive with high capacity are always fagile and they get crashed easily.why not try a new hard drive.
Jan 27, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
335 people viewed this question
Alun Cox
David Payne
David Payne
