Belkin modem router
Until recently my belkin modem router was working perfectly.Now my two laptops can access the internet wirelessly but my desktop pc to which it connected by wire will not connect at all.Any ideas please??
Check the network cable
Posted on Mar 10, 2008
  • 96 Answers
Check all connections from PC to router...
Unplug/re-plug... you should see notifications...
Posted on Feb 10, 2008
Router connection fail
do you have internet with the modem? if you do then router is not configure correctly. If you do nothave internet ask you ISP why you are not online with the modem directly.
Sep 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin G Wireless router not connecting to net
Did you save the IP addresses ?You may have to configure the router manualy go to your network ,settings or type in run box IP config and see whats going on
Dec 27, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin N Modem Router If main PC which is ethernet wired to the modem router is swtiched off, laptops cannot access the internet. Does this mean that the PC to which the modem router is connected has to...
it will as long as the modem/router is connected to a phone line, instead of the pc, the only cable connected to the pc should be a ethernet cable; or you have the pc networking set that it connects via another pc instead of through a gateway, re run the wireless network wizard.
Sep 05, 2008 | Belkin Computers & Internet
Belkin N Wireless Router doesn't connect to Modem
If router is brand new you should have a set up disk. the set up disk will walk you through it or you might log onto Belkin site to see a walk through set up. If you can access internet from modem to router to internet. That means router is functioning properly. To go completely wireless you will need to secure your network and setup your access codes. Definitely use the setup disk to do this. A unsecured wireless network is a nightmare waiting to happen. Good luck
Sep 01, 2008 | Belkin Modem connector (R6G064-R-50)
Belkin wireless problem
If you are connected straight from the modem, your router will not have internet access, only if your modem is connected to the router you will be able to go online wireless. connect your modem to the router nad router to the desktop, so that you can access both wired and wireless connection
Aug 12, 2008 | Belkin (F5D9230-4) Wireless Router...
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin n1 wireless usb adapter
Dear Friend,
1. Connect your ISP modem to your PC and configure as Bridge mode.
2. Remove your ISP modem and connect your wireless router to your PC and configure as PPPOE mode. (refer if any doubt on configuration)
3. Now connect your ISP modem to wireless router, The modem should connect to your WAN cable.
4. And Give the wireless router's IP in your laptop as Gateway (In TCPIP settings of your Laptop wireless adapter / or configure DHCP)
5. Now you can access internet on both systems.
Feb 02, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Router not working unless
Several questions --
How is this wired?
Comming from the Cable (tv) or a phone wire (DSL) from a phone jack you are connected to a modem/whatever supplied by your service provider. Then an ethernet cable (looks like a fat phone cable with extra wide connectors (8 metal connectors instead of 2 or 4) connects the modem/whatever to your router's WAN port (the separate port not one of the block of 4) and another ethernet cable connects the one of the outer's Lan ports (probably block of 4) to the desktop computer and your laptop operates wirelessly. Is this correct? If not explain houw this is wired, please. For consistency please start at the cable or phone wire.
Does your desktop do anything to log into the internet with a userid and password maybe?
If so who is your internet service provider?
We may need to change the login process and get it into the router and off the desktop.
Jan 02, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin WirelessG Plus Mimo
Consider securing the wireless connection if you have not done so your neighbors MAY be able to utilize your wireless connection and your bandwidth if you do not.
Secondly if I understand you you have 4 computers using the router to access the modem connected to your Internet Service Provider; three using wires and one using the wireless. First have youneed to confirm that your internet service provider allows multiple devices to share the connection (which is what your router is trying to do). If so do you have to logon / login to your ISP to access the internet? (This login may be hidden from you in the modem provided by the ISP) Research if it is required to have your router logon to the ISP instead of either one of the computers or the modem in order to support multiple users. If that is the case you will need to determine if your router is capable of performing the logon for you and configure the necessary devices appropriately.
I can possibly help with the above but will need to know your ISP, and the manufacturer and model for your router and wireless card(s) to assist in configuring the components. The manufacturer and model information will also provide a basis for securing the wireless network if desired.
Dec 02, 2007 | Belkin (F5D7231-4) Wireless Router
Computers & Internet Logo
187 people viewed this question
David Payne
David Payne
