FixYa.com
Tags:
Acer n311 Pocket PC
Acer n311 (by 3 users)
posted by absyed on Dec 13, 2007
I have an Acer n311. For the past few months after I have been using the pda for about 3-4 minutes the screen freezes, and none of the buttons respond (to switch it on or off). The the only way to get it to work is to remove the battery and re-insert it, and do a soft reset. But often it will again freeze during the boot-up process.
I thought it might be the battery, but a new battery has made no difference.
Anyone able to help?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by hoongwai, posted on Feb 24, 2008
I had the exact problem. Except now it's worse. I used to overcome the problem by performing a hard reset and loading the bootloader (for some reason it didn't wipe the memory), but now even that doesn't work anymore. and my pretty little Acer PDA is just a useless slab!
Comment by tom4061, posted on Dec 24, 2007
I am thinking about a hard reset if this is possible with it freezing every time it boots up. That will be my last resort if there is no other way.
HELP!!!!!!!!
Solution #1
posted on Dec 29, 2007
Not Rated (0)
Horciciatko
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
hi. the question is, which ROM version do you use. just go to settings and choose about... there you can find info about the current ROM. look for the last two numbers (they should be between 16 and 24 which is the latest and stable version) here is the short guide how to proceed with the update an here you can download mentioned ROM. I advise you not to restore your device afterwards, it won't work!
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these PDAs problems?
PDAs
my ds does not respond
my ds does not respond to ds... Answer This...
PDAs
I have a B &
I have a B & D battery... Answer This...
PDAs
maybe problem with pocket p.c
maybe problem with pocket p.c... Answer This...
PDAs
i need a user manuel
i need a user manuel for a rca... Answer This...
Acer n311 Pocket PC
Acer N331 not recognized as...
Hello, I'm the unfortunate... Answer This...
Repair Service
Find PDA Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
