Question about Symphonic ST419E TV
SYMPHONIC model ST419E LOST Remote ~ NO INPUT ~ RCA Universal won't work!
I lost the remote
I hooked up my dvd player
can't get the input to change
bought rca universal remote but everything else works except the input function
is there anything I can do to fix this? I'm totally broke and can't buy another remote for awhile now.
please help.
I want to watch my dvds.
5 Suggested Answers
  • 125 Answers
SOURCE: no input channels
Universal remote control are normally programmed for basic functions, ie. chennel up down, volume up down, numbers, etc. This is even written in the manual that they do not guarantee that all functionality can be used. Here are your options: 1. Try all the codes that match your TV, there is a slim chance that the other code have the functionality that you need. 2. Buy the original model remote control. 3. If you know of someone that have the same TV, buy a universal remote control with 'learning' function and copy the signal from the original remote control. I have the same problems before. Now I use my Casio wrist remote control to copy the special functions such as A/V so that even if the original remote control is lost, I can still use these functionality
Posted on May 24, 2007
  • 4 Answers
SOURCE: I own a symphonic 27" television
I had this problem on a symphonic 27 inch TV I just bought from a friend who no longer had a remote. The thing with the menu and buttons on the front of the TV doesn't actually change the TV to true game mode. I don't know what it acutally does, but it isn't really in game mode. When it is in true "game mode" you can't change the channels until you turn game mode off. What I did was bought a universal remote (a specific one that someone told me about) for 8 bucks at walmart and I was then able to switch to game mode with the Input select on the remote. The remote I bought that actually worked is this one: http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=acc_glance_ce_ai_-2_1_tit/002-3174824-8273629
Make sure you look at it before you buy it and make sure it has a button that specifically says "input" on it. I know that some of the universal remotes don't have an input select button or one that doesn't work. As long as you get a Philips-Magnavox that has that button, you should be ok. Much better solution that paying 30 bucks for a new remote specifically for the TV. Hope this helps.
Posted on May 05, 2008
  • 54 Answers
SOURCE: need codes to control symphonic 27
  1. These instructions come from the RCA website. The crucial step is to keep pressing the reverse button.
  2. Turn on the component (the tv, dvd, etc).
  3. Hold the TV (or DVD) button and the on/off button at the same time. It will stay lit.
  4. Press the play button every five seconds until the component turns off.
    • Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
    • If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  7. To save the new code, press and release the STOP button.
  8. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
Tips
  • Turn on TV
  • Hold in the TV button and the ON/OFF button until the ON/OFF button stays lit
  • Press the PLAY button every 5 seconds until the device turns off
  • Press the REVERSE button every 2 seconds until the device turns on
  • Press the STOP button to lock in the code...the remote should work now.
  • Important to press reverse button every 2 seconds, not just once.
Good Luck!!
Posted on Aug 18, 2008
SOURCE: Lost Remote
the sony rm-v310 universal remote solved my problem. its about 15 bucks and worked on my symphonic 20" tv. bestbuy should have one.
Posted on Nov 08, 2008
Trying to hook up an emerson dvd player to tv and its not working? older tv it has no cable hook up or control box for channel set up, shouldnt the dvd player still be able to work though?
IM GUESSING THIS MIGHT BE AN RCA TELEVISION? if you dont have an rca in hook up on the tv give up and buy a new tv or you can find an older item what it is is a switch that has an rca input and a coax output it was used to hook up the older video game systems it is still sold in most stores and that will work if you do have rca inputs and lost the remote you need to get a universal remote to switch the input on certain older rca tv's you could go to channel 00 and it would set it to the input with the switch you shoudl be able to use it by putting the tv on channel 3
Feb 28, 2010 | Emerson EWD7001 DVD Player
Rca tv model f35673mb - lost remote.... switch to video ???/
I asume your game systems and dvd player are hooked up via the rca inputs.So all you would need to do is purchase a universal remote,program it for your tvand press ch00 which should be the video input.make sure your dvd or game system is on so you know if you are on the right channel
Nov 09, 2008 | RCA F35673MB 35" TV
Mar 04, 2008 | Symphonic ST419E TV
Lost Remote
Dec 15, 2007 | Symphonic ST419E TV
Sanyo lost remote
I had the same problem. Just got a DVD player and hooked it up and nothing. I got the Sanyo TV from a relative. Anyway channel 3,4 not work and when I go 00 still nothing. Then I pressed Input on the remote and a blue screen popped up. Turn on the dvd and now it works with channel 4. So I think any remote will work just put the tv to channel 4 and press input on the remote.
Dec 02, 2007 | Sanyo DS31520 31" TV
Lost remote
lost remote, can not switch imput
Nov 01, 2007 | Televison & Video
Universal remotes
You have to use the input selection button. Example like video, video1 video2, aux etc...
Sep 01, 2007 | Symphonic ST419E TV
Lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter? i have a rca univeral remote, but it will not change my tv to input or output.
using the menu button on the t.v. set an alarm for 1 min in the future. have the t.v change to channel 00 or the input channel @ that time. turn off the t.v and wait until the alarm turns the t.v on.
Aug 11, 2007 | RCA 27F534T TV
No input channels
May 23, 2007 | Symphonic ST419E TV
Symphonic ST419E TV Logo
133 people viewed this question
Top Symphonic Televison & Video Experts
SHARCNET-USA
SHARCNET-USA
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
