my kp 53s65 picture seems to be darker now than when i bought it. is this normal in a dlp tv ? someone told me to change the buld but i was not sure if i should.
KP53S65 is a rear projection Sony several years old--It is not a DLP and does not have a bulb--it has three picture tubes---if the set has not been serviced in a long time here is what you can do to try to improve it:
1.) Unplug set 2.) Remove back cover 3.) You will see 3 black lens (one for each tube) 4.) With a paper towel (spray glass cleaner on it) clean the dust from the three lens---if they have not been cleaned in a long time and have dust on them the picture will be darker and less distinct.
5.) Replace back cover and plug set in to see if this has helped----I have seen some where there was so much dust on the lens that it looked 50% better after just cleaning the lens--depending on area you live in--should be cleaned once a year.
I do this here for free so if this has helped you please take a minute to give me a vote here.
i have a sony kp-53s35 and the picture is not in sharp nor colored. but it does show a picture. you...
(More)
i have a sony kp-53s35 and the picture is not in sharp nor colored. but it does show a picture. you can tell what is on but, like red looks brown blue looks grey, and fixing the color, sharpness, and the hue does not fix it.
when i turn on the tv the timer button starts to blink and it makes a noise every once in a while....
(More)
when i turn on the tv the timer button starts to blink and it makes a noise every once in a while. the tv sounds as if it turns on and then it has a black screen and i cannot hear anything. but the tv turns on and the remote works.
i was watching tv today and the screen and sound just turned off, i have the back of the tv pulled...
(More)
i was watching tv today and the screen and sound just turned off, i have the back of the tv pulled off so i can see inside but i have not touched anything, when i try to power on the tv the red light on the front just blinks, is there a fuse or something that i can check on
Started smokingfrom the I would call it the motherboard.and screen is blank.What would be the...
(More)
Started smokingfrom the I would call it the motherboard.and screen is blank.What would be the problem and how do I fix it?
Sony KP53S65. When unit powers on the sound starts up but the picture takes longer to display. The...
(More)
Sony KP53S65. When unit powers on the sound starts up but the picture takes longer to display. The picture then blinks on and off periodically for a minute or two before it remains on and works properly. The picture tint seems much redder than usual, could this have something to do power up issue? I opened the unit and vaccuumed/blew out all the dust, windexed the tubes and mirror. I then turned it back on with the back open and looked into the tubes while it was on. The Red and blue tubes have a clear image however the green tube image does not look nearly as distinct as the other two. Picture is crisp and sharp once it stops blinking except for the reddish tint. Could this all be the result of one problem and if so what do you think it is?
