Question about Motorola Mobility H700 Wireless Headset
Motorola h700 i paried and used the h700 with my first razor phone. 2 months ago i got a new razor phone and now i can't get the h700 to pair up. i have gone through all the instructions on setup. i can't get the h700 to turn the purple color and i can't get my new phone to find the h700 either.
  • Anonymous Jan 01, 2008
    i did the same thing. i went into my setup, clicked on the connection button, and put in the find label: h700, and clicked Find Me. it took a long time and it never found it! it also said something like: discoverable 60 seconds. i don't know want that meant. am i doing something wrong? thanks.
    Problem Solver:
  • 9 Answers
5 Steps
First, CLOSE your boom
Second, Hold the talk button( about 5 secs it should turn to purple color)
Third, DO NOT release the button while opening your boom
Fourth, your BT should be in discover mode( show the steady light not flashing )
Fifth, open your phone bluetooth and search for device. Choose your bluetooth that appeared on the list ( pair code normally "0000" ).
Posted on Jan 08, 2008
My Motorola H700 is paired up but won't connect with my Blackberry, what can I do?
Posted on Jan 10, 2008
The Motorola H700 has Bluetooth v1.2 which is backward compatible with v1.1. The headset works with both Hands-free and Headset profiles and is easy to pair with devices running various operating systems and software. We tested the headset with the Motorola SLVR, Palm Treo 650, the Nokia 9500, the Cingular 8125 and the Cingular 2125, and the headset paired with all devices with ease. To pair the Motorola, turn off the headset first then hold the Call button until the LED ring turns purple, quickly open the boom so that the LED stays solid purple, the headset is now in pairing mode. Use your mobile phone to discover and pair with the headset using “0000” as the default pass code. Call handling between the phone and the headset transferred smoothly and the headset will play notification or a ring tone when a call comes in. When working with the Treo 650, the H700 has an uncomfortably long delay in notifying an incoming call. It starts to ring after the Treo 650 has already ringed 2-3 times. The connection between the phone and the headset is solid. When we paired the Treo 650 to both the Motorola H700 and the Parrot 322 car kit, we can pick up calls on either one and the Motorola H700 worked reliably in this set up.
Hope I helped Dr Reed
Apr 06, 2010 | Motorola Mobility H700 Wireless Headset
Problem with Blackberry Pearl 8100
Did you try deleting all devices paired and then try pairing again?
May 20, 2008 | Motorola Mobility H700 Wireless Headset
Tryin to get bluetooth earpiece to work on motorola razor phone
Go to this website, then click quick start, then click pair h700 with your phone and then it will give you steps to take to pair it. If i helped please leave me a rating.
Mar 22, 2010 | Motorola Mobility H700 Wireless Headset
when using a phone like the blackberry, remember that you have the ability to hit the lower left "ALT" key- this "shift" key, when hit each time you need a capital letter- or in this case, you need to enter '0000' as the password/ key, and to get a zero on the blackberry, you have to hit the ALT key each time you want to set a zero. hope this helps, i stumbled onto this one by accident when i had the same
Aug 13, 2009 | Motorola Mobility H700 Wireless Headset
H700 is paired to phone and computer but will not connect
make sure your bluetooth function on your cell phone is on then if this doesnt work delete this device from your phone an reinstall it
Jan 11, 2008 | Motorola Mobility H700 Wireless Headset
H700 unable to pair up 'service not supported'
The term "service" refers to other types of services supported by bluetooth technology like keyboards, mice, etc. There's a lot more than just headsets now. I suggest checking the bluetooth options on your phone to see if there is a refresh service or other option....there is one like that on my blackberry that I once had to use to solve a similar issue. Have you tried disabling bluetooth, rebooting phone, enabling bluetooth, and rebooting phone before pairing? Also, look to see if there is an encryption on/off option on the phone...this could be causing an echo in either state due to interference...try switching encryption on/off. Also, check your update options on the phone, you didn't say which kind of phone it is but some can get firmware updates that may be needed for bluetooth to work well. Finally, you may get results by deleting the device on the phone and re-adding it thru discovery.
Jun 23, 2007 | Motorola Mobility H700 Wireless Headset
My H700 does not connect. When I attempt to connect it shows the disconnect option but it isn't connected
My bluetooth does not work at all. Have had it on charger for days. It does turn purple, but does not work when I put it in my ear. Have checked the connection. It just seems dead. Bought it last November, but first time I've had a problem. Can you help? Barbara
Jun 20, 2007 | Motorola Mobility H700 Wireless Headset
H700 not working properly
I had the same problem with my Razor and the H700. I removed the device from the phone and reinstalled and that fixed the pairing probelm...Now I have another problem. I can hear the party I'm talking to just fine but no onee can hear me...this is my second Motorola ear piece and I've had the same problem twice...I think its a microphone problem...anyway, try to unistall and then reinstall the ear piece, that should fix your problem
Jun 19, 2007 | Motorola Mobility H700 Wireless Headset
Help needed in paring my H700
In order to pair with this device you must follow these steps: 1. Close the mike on the H700 2. Hold the center call button on the H700 until the ring in the center turns violet. 3. Open the mike on the H700 4. Have your phone search for bluetooth devices and follow the propmts 5. If your phone requests a passkey, enter 0000 This is the default for all Motorola devices Hope this helps.
Apr 01, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility H700 Wireless Headset Logo
225 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
