GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Problem for GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with...
Freezer coils freeze up then frig warms
By dbrown7169 on Sep 19, 2009
I continue to have freezing problems with the freezer, suppose to be a frost free unit. If I thaw freezer everything works fine for about a month and it does it again. Help
Best Solution
posted on Sep 19, 2009
Very Helpful)
Krazytech
Rank: Guru  GE Expert
Rating: 90%, 663 votes
Defrost has three parts a heater - adc/control - defrost thermostate...and three can cause a defrost system to stop working...
The problem is probably the defrost heater, that's one of most common parts to go out on these GE's it is a glass tube heater.
If you remove the rear panel in the freezer you will see the heater below the evaporator coils. If it's out it's usually discolored.
Your model does not have a timer, the control board does that
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Right on...tube is discolored. We're gonna replace and try! " - dbrown7169
Solution #2
Helpful)
seth765
Rank: Guru
Rating: 89%, 64 votes
this is more than likely a defrost sensor or timer that is not allowing the fridge to go into a defrost mode.you could also have a problem with the thermastat the allows the fridge to run for longer periods of time.
Was this helpful?
Yes
No
Popular Solutions for GE Profile 26.6 cu. ft.
Questions and Unsolved Problems for GE Profile 26.6 cu. ft.
Do you recommend GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW?
Answer
Answer
Water will not come out the front door. The ice dispenser is working but the water side is not.
Answer
Car Starter Installation Instructions can some one sent detail how to install it
Answer
The icemaker makes a ticking noise, but does not produce ice.
Answer
ge side by side everyonce in a while it will just stop working then when i reset the breaker its... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
