Question about Hitachi 50DX20B 50" Rear Projection Television
Hitachi 50DX10B Power issue
TV manufactured in May 2001. Unit Powers off, Red Led stays on. Wait for several minutes unit will power back on only to shut off again. Stays up anywhere from 30 seconds to two hours. Any idea?
  • stricklandda Oct 02, 2008
    mine powers off by its self and wont come back on till you unplug the set and plug it back in and then only works for 1 hour to 1 min
  • Anonymous Mar 24, 2014
    the tv will play for hours and then the red power button will shut off. when i try to turn it back on with the tv remote the light does not turn on, and i have to wait for hours sometimes days before the power light will come on and the tv will play.
    Novelist:
    Champion:
  • 232 Answers
Rollo, broken solder connections either in low voltage or sweep section of the board, probably in the horizontal out put area but could be anywhere. If you want to attempt the fix the board has to come out and you`ll need a bright light as well as a good magnifying glass to find the broken joints and then re-solder them, Be certain your tv`s AC cord is removed from the wall outlet before doing any soldering, good luck, BMW Rider
Posted on Dec 14, 2007
Sharp PG-M20X digital projector runs 2-5 minutes then shuts off
the Fan has the problem , I had the same of yours. I noticed some particle was inserted in the center of the fan and removed it , worked perfectly. If old one produce little particles.
Good luck.
Dec 03, 2009 | Sharp Notevision PG-M20X Multimedia...
Hitachi 55FX48B 55 in. loss of power...
Try first unplugging power cord for ten minutes, it looks more like your power unit has gone.
Sep 02, 2008 | Hitachi 55FX48B 55" Rear Projection...
55hds69 hitachi plasma
I have had some issues with high ESR readings in the capacitors in the scaler circuits in those units. Do you have an ESR meter to check the caps in circuit?
May 14, 2008 | Hitachi 55HDS69 55 in. Plasma Television
TV Powers off
tap on the power supply borad not to hard
and have some one let you know if pix fark out
go all thur all the board soune like you have bad solder jonts
Aug 12, 2009 | Televison & Video
Hitachi 50dx10b
Try unplugging and plugging back up the power cord to reset it.
May 14, 2008 | Hitachi 50DX20B 50" Rear Projection...
LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Apr 14, 2008 | LG 26LX1D 26 in. LCD HDTV
OFF AFTER 10-15 MINUTES
This is usually caused by damaged capacitors (Akai uses very cheap components) on the power supply board. There are nine large electrolytic caps that have to be replaced. Hope this helps you out.
Feb 05, 2008 | Akai LCT2662 Television
Unit will not turn on from standby
I had a similar problem and it was caused by my cable box being in scart 1 as soon as I changed over to scart 2 the problems went away,
Nov 04, 2007 | Hitachi 42HDS69 42 in. Plasma Television
Pulsating power LED. No picture. No sound
Either the main smoothing capacitor or the voltage regulator are faulty. You may find that the power LED will stay on after pulsating for several minutes, at which time you can switch the TV on.
Aug 08, 2007 | Hitachi C25-RF35S 25" TV
Hitachi 50DX20B 50" Rear Projection Television Logo
125 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
