Question about GE Ovens
I have an old GE electric oven that came with a home I purchased in 1997. The oven could be over 20 years old. Its model JMS27GJ. One of the heating elements on the stove top won't stay at the temperature its set at. If set on low it might warm up to hot after 5 minutes of sometimes it will suddenly heat up to very high after 30 minutes all by itself. Many meals and pots have been burned as a result. The problem is it often gets much hotter than the setting its on - but this happens irregularly.
    President:
  • 1,865 Answers
Thermostat is bad, replace it
Posted on Sep 19, 2009
Testimonial: "Thanks for your suggestion. One question though. Can the bad thermostat be replaced by replacing the burner switch or some other part? inter215@yaho"
  • buffalonyman
    buffalonyman Sep 20, 2009
    The thermostat is a copper tube looking device mounted inside the oven cavity
SOURCE:
Aqua GE Wall Oven SN10729 (Can't find a part number) 1950's-60''s
from the serial # it was made in september the second letter N is either 1956 or 1972.
take a look at this site it'll lead you to ge heating elements
see if there is one that resembles your's.
then call them. they are very helpful and may be able to tell you where the model # is. ask if what you're seeing might fit.
here's the link...
http://www.appliancepartspros.com/ge-wall-oven-heating-element.html
Hope this helps a little.
Happy New year
Jan 02, 2018 | GE Ovens
Receiving F3 Code
HI, no need to replace the unit at this time. this is a Open or shorted oven temperature sensor (RTD).
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jul 16, 2009 | GE JRS04 Electric Single Oven
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
Install bake unit in GE wall oven model JKP07J
I honestly believe you are right. you should be able to wiggle it back and forth and pull it out.
Dec 27, 2008 | GE JKS05 Electric Single Oven
Wierd problem with ge eletric oven / no heat
check the electrial connection at the back of the range, also check the breaker
Mar 31, 2008 | GE JKP15 Electric Single Oven
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Heating element in GE Range Oven
get the model number and order the exact repacement bake element
Mar 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
172 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a GE Oven Expert? Answer questions, earn points and help others
