Question about Nintendo Revolution Console
Nintendo nes just got my Nintendo nes. Husband cannot figure what he is doing wrong. There ere only two little plugs to plug into our TV. One is for video and one for audio, right? We cannot get it to work..........what are we doing wrong the power is on at the box----- jeezzzzzzzzz
    Problem Solver:
  • 19 Answers
Did you try hooking it up with a av connector the rca jack might not be working
Posted on Jan 18, 2008
No audio video
NES AV to TV Hookup
Note: This type of connection is not possible with the newer-style NES.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the AV cable into the Video "in" on the back of the TV. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
On the other end of the AV cable, plug the yellow end into the "Video" (yellow) input. Plug the white or red end into the "Audio" (red) input, on the back of the NES.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the system. Use the far left port for player one.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Press the Power button in on the front of the NES.
Turn on the TV and locate the input select. It is often called: TV/Video, input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You are ready to play!
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Jun 05, 2012 | Nintendo NES Console
I have the first nintendo nes and i dont have the rca's i have the one you hook through the cable and it comes on but i cant find the channel to put it on to play the game ! What am i doing wrong ?
Original-Style Super NES RF to TV Hookup
Installation Steps:
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn on the TV and set it to the appropriate channel (3 or 4.)
The game image should now be displayed on the TV screen. You are ready to play!
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Nov 25, 2011 | Nintendo Super NES Console
I just tried to try my NES (wichs hadn't been use for a long time) again. When i plugged everything and turned the NES on, the light start blinking. Then, I put a game in it and opened the tv on channel 3....
You can try to change the input to Video instead of channel 3 since you're using a RCA (Red, Yellow and White) cable.
Thanks for using Fixya.
Jan 31, 2011 | Nintendo NES Console
Hi, I'm looking for a little help. I've looked out my old NES Nintendo, plugged it in after a good 10+ years in storage, I've got the RF cable plugged into the RF jack socket on the back of the console and...
If you are using the RF cable you should be able to see video as long as you are on the right channel set from the RF cable, if that isn't working then just try plugging in the video cables and see if it is just the RF cable not working.
Dec 20, 2010 | Nintendo NES Console
How do i properly connect my nintendo nes sytem to my direct tv. when i use the av cables i just get a blue screen. can u give me step by step to connect correctly.
Installation Steps:
Installation Steps:
Place the yellow end of the AV cable into the Video "in" on the back of the VCR. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
After system is connected to the VCR:
Plug the Controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end into a wall outlet.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press play, make sure you see the movie on the TV, then press stop. This puts your VCR into VCR mode.
Turn on the NES by pressing the Power button on the front of the Control Deck.
Turn on the VCR and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The Game image should now be displayed on the screen.
Recording Game Play
Set up the NES to play a game.
Insert a videotape and press Record. You can now tape your video game playing for posterity!
Sep 06, 2010 | Nintendo NES Console
Hi i just bought a super nes system it came with RF switch power unit which i have connected to the appropriate connections, i have an LG TV with an golden eye and don't seem to be able to tune the...
Make sure everything's connected in the correct sockets. Turn the SNES on, change to one of the Analogue channels (one of the channels which you control with the TV remote) and start scanning for a signal. The RF cable has to be connected to the analogue port (where a TV aerial would plug in to get analogue channels) and the SNES needs to be switched on.
The alternative is to get a SCART-compatible cable that works with a Gamecube or an N64 and use it with the SNES, as Nintendo had the foresight to add an EXT port which'll let you play the SNES on an AV channel.
Jul 09, 2009 | Nintendo Super NES Console
Hi i just bought a sper nes system it came with rf
If I am understanding...
If the RF switch comes with a power cord on it, it MUST be plugged in to work. Try plugging it in.
Also check your tv settings. I don't have an HDtv but I do know they have multiple options of "inputs"
If it is an RF modulator and not just a switch, check the settings on that as well. On the one I own I have to designate channel 3 or 4, that could make a difference.
I dont know how to plug my NES into my t.v.
If you are talking about the original Nintendo the original cable that came with it will hook up 3 different ways 1) way is through the vcr through the rca inputs ,2)if your tv is capable use an S-video cable. You can also run it through some of the satellite boxes. 3)hook the tv end of the able to the tv and sat to the little box.
Jan 02, 2009 | Nintendo Super NES Console
Nes Nintendo Channel Trouble
are you using a/v (audio/video cables with rca ends), or direct to cable input on t v.? if direct to t v, did you check ch switch on back of system deck? otherwise is t v programmed for the correct INPUT. T V, AV1. AV2. OR AV3? ANOTHER PROBLEM WITH OLD NES IS YOU MUST CLEAN THE GAME EVERYTIME YOU INSERT IT. TO CLEAN MIX ALCOHOL/WATER 1-1 AND USE QTIP. RUN IT UP AND DOWN BOTH SIDES OF CONTACTS. IT WILL DRY RIGHTAWAY.
Sep 19, 2007 | Nintendo NES Console
Problem with NES
Check on the back of the nintendo system if it is on same channel as tv, little switch is on the back next to the power cord.
example..tv channel 3 and nintendo system channel 3
If that doesn't work your cable is not properly connected, You can't use both rf switch and av cable. It one or the other. rf connect in the back and to coax cable. Av cable connect on the right side of the system and front input on tv..
Make sure your games are clean also. Good Luck.
Sep 17, 2007 | Nintendo NES Console
Nintendo Revolution Console Logo
35 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
