Ford 8N Tractor Logo
Posted on Sep 19, 2009
The steering column shaft in my 1954 Ford 8N tractor broke and I need info on howe to fix it.
Ford8Ncom
Level 1:
Habit-Forming:
  • Contributor 11 Answers
  • Posted on Dec 22, 2009
Ford8Ncom
Contributor
Level 1:
Habit-Forming:
Answers
11
Questions
0
Helped
11402
Points
16
Not sure, but if it's a 1954 model, it's not an 8N. 8N was only built thru 1952.
But sounds like you will need a new steering shaft.
www.Ford8N.com
2answers
Is there a simple way to replace a fan belt on a Ford 8N Tractor? This 8N has front drive hydraulics, and there a shaft in the way.
Question edited to add the word 'Tractor' and correct spelling.
Question moved to a category that fits 'Ford, 8N and Tractor'.
Being that old and American, the bolt is probably something like 7/16" Whitworth. These videos may help, but I haven't watched them. You can not get adjustable sockets that have steel pins that grip the flats of the nut.
https://www.amazon.ca/Multi-Size-Adjustable-Regularity-Irregularity-Improvement/dp/B083F3LXT5
https://www.google.com/search?q=ford+8n+replace+fan+belt
2answers
Don't know how to read the hydraulic dipstick for a 1944 ford 2n tractor
Ford Tractor Hydraulic System - My Ford Tractors
www.myfordtractors.com/hydraulics.shtml
All N-Series Tractors - Ford-Ferguson 9N, 2N, and Ford 8N ... 6 - How long has it been since you changed the hydraulic fluid? ... If that didn't do it, read on. ... then remove the bottom bolt from the inspection plate that has the hydraulic dip-stick.
Yesterday's Tractors - Fifty Tips for Ford 9N, 2N and 8N ...
www.yesterdaystractors.com/articles/artint268.htm
I'd like to say that the reason I have an 8N Ford tractor is because that's the tractor ... The N tractors have a common sump for the rear end, hydraulic pump andtransmission. ... (Read the label.) .... Take the inspection plate with the dipstick off.
Ford 8N, 9N, 2N, NAA Tractors Information - SSB Tractor ...
www.ssbtractor.com/wwwboard/messages15/
Helpful information and resources on Ford 8N, 9N, 2N, NAA tractors from SSB Tractor, a leading provider of tractor parts, manuals, implements ... 1944 ford 2n: What type of oil to use? and whats the oil pressure should be? ...... N Series Trans/Hydro Fluid - Interesting To Read ... Ford NAA/Jubilee Hydraulic dipstick location?
What year is this tractor ?
The Ford 8N? Sometime between 1947 and 1954.
Shermon shifterin ford 8n
http://www.yesterdaystractors.com/atrp/specs/ford.htm
The above link is an excellent site for help. Can you see if the shaft is turning when you try to shift the Sherman Hi/Lo transmission.?
The Sherman units are installed inside the housing between the engine and Ford transmission and I believe you would have to "split" the tractor to access actual Sherman unit. It sounds like either the Hi/lo lever is slipping on the shaft or has broken internally....good luck. Try doing a search for ( Sherman transmission Ford 8n tractor help) there are a lot of Old timer experts out there and this was a very popular addition to the 8n's
I have an 8N Tractor and the gear broke off of the starter shaft. How do I retrieve the broken pieces out of the tractor?
There should be a clutch inspection plate on the bottom of the bellhousing, take that off and you should be able to fish them out.
lp
Is there a simple way to replace a fan belt on a Ford 8N?
there should be a coupler on the driven shaft. take out bolts and gently pry apart. this should allow enough room to work the new belt around the crank pulley
Ford 4000 starter only works when I hit it with a hammer. What does that indicate?
the bendix unit on the starter shaft is sticking. You need to pull the starter and clean the shaft up and lightly grease it so the gear can move out when you engage the starter. worst case scenario you may have a badly worn shaft and need to replace it with a new starter. hope this helps you...
In 3rd gear the front wheels shake on 8N ford Tractor
The quick easy answer is put your feet on the steering shafts just ahead of your feet when sitting on the tractor when driving at speeds causing the shimmy.This is what most people do.
The longer answer is a new or rebuilt steering box or possibly adjustment.
Some (most) boxes have play that cannot be adjusted tight even with a rebuild.
Ford 8n gets hot, may need to be timed,Step by step needed.
This is everything that i know that will make an 8N run hot...a stopped up radiator(inside)..a radiator that is filled with debris in the cooling fins..a bad thermostat(located in the upper radiator hose..if it has one).....a stopped up block..bent fan blades...fan shroud missing..a bad water pump..the fan belt slipping on the water pump ..a blown head gasket..low coolant..i hope this will help and one of them should fix it ..if not...please write me back
Top Ford Toys Experts
Kardoc
Paul Katynski
Paul Katynski
Are you a Ford Toy Expert? Answer questions, earn points and help others
