Question about Durabrand DWT1304 13" TV
Hooking up a dvd player to my durabrand tv
I cannot get my dvd player to work at all with my tv
  • 4 more comments
  • sublime Dec 26, 2007
    I have an older sanyo tv and I can't get any dvd player to work. I have no remote for the tv. There is no video button on the tv itself, i just put to channel 3 and hook in the video and audio cords and it won't work.
  • Anonymous May 30, 2008
    I have a westinghouse tv/dvd combo which the dvd part is not working. I just bought a magnovox dvd player to use with it, but I can not get it to work.
  • sindybell Jul 10, 2008
    how do i get the video and audo outlets to work
  • Anonymous Aug 22, 2008
    no menue no prompt
  • GETV Jan 17, 2009
    I have a GE TV with a built in VCR. I want to connect a Sanyo DVD Player to my GE TV.
  • dixiegrl1985 Feb 07, 2009
    I have a small insignia dvd player that i cannot get to work with my samsung t.v.
If it is a durabrand dwt1304, you cannot switch the input to EXTERNAL (the front jacks) without a remote. There is a good one at Radio Shack for eight bucks, the 3-in-1 remote. The program code is 0171, and you switch the TV inputs with the A/B button.
Posted on Sep 13, 2008
Fuck me plz!
Posted on Jan 12, 2008
I dont have a remote for the tv abd i wanna plug my ps2 when i plug it doesnt work what can i do
Posted on Jul 14, 2008
I can't get the DVD player to view dvd on tv
hi konni.
this is all i could find .
DVD player not working with TV By Charlotte Parker 25 Aug 2017
You've got your Sky Box, your TV, your DVD Player and your surround sound; you've also got your digi-box, your DVD recorder, Blu-Ray Player. With all that equipment, if something goes wrong it can be tricky to track down the issue. This article explains why your TV isn't playing DVDs and how to get it sorted out.
Figuring out the problem
Figuring out why your DVD Player isn't working with your TV is a process of elimination, so work through the steps below to figure out the cause of the problem.
The problem could be:
  • The connector cables/connections.
  • The DVD disc itself.
  • The DVD Player's optical reader (the lens which 'reads' the DVDs).
  • The TV.
Before doing anything, check all your connector cables. Make sure that all connections are in properly, and that the cables are in the right place.
One of the most important connections is the cable that runs between your TV and the DVD Player. If it isn't in place, then your TV can't read the information from the DVD Player and the film won't appear on your TV.
The DVD disc itself
Check for scratches, chips, smudges and any other marks. Test the disc isn't the problem by trying a different one in the player. If the new disc works, then the first one might need replacing.
The TVTry changing channels. Lots of TV's have a default channel specifically for DVD players. Have a look between the channels to see if the DVD menu appears.
On modern televisions, especially those connected to Digi-boxes or Sky Boxes, there's usually a 'Source' button on the remote control. Find it and go through until you reach the right setting for playing DVDs. To go back to watching normal TV channels after the DVD has finished, go back to the source button and change back to the original source.
That should be all you need to know to get your DVD player working with your TV
if none of above works then try putting a lens cleaner through it to try and clean the lens that reads the disc.
Nov 05, 2017 | Televison & Video
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
Getting dvd player to work
OK from your DVD player connect the Composite video output jack of the DVD player marked in yellow to the composite video in of the TV. The connect the audio output (red and white) to the audio input of the TV. Then set the TV to connect to the composite port should have at least AUX1.
Oct 09, 2007 | Philips DVP5140 DVD Player
DVD model #mwd7006 sound but no picture
  • To reset the DVD player unplug the DVD player for 10 seconds.
  • Confirm that the TV has been set to the corresponding video connection of the DVD player.
  • DVD player has three video outputs.Video, S-video and RGB-component.
  • If current connection to TV is not working and the TV has an alternative video consistent with the DVD player try the second.
  • Try DVD player on another TV
Nov 24, 2015 | Televison & Video
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
Which channel do i put the tv on, and which do i put the dvd player on in order for them to work together? I have a sanyo flat screen tv and a sony dolby digital dvd player, and i don't know how to get...
You do not put your TV on any channel. DVD players need to connect to a TV with video cables and not a RF cable. This means 3 connection options on how your DVD player should connect to your TV. First, since your DVD player is NOT a bluray player, then HDMI connection is not needed. 2nd, the best choice would be component cables. These are the RED/GREEN/BLUE RCA connector that are on the back of your DVD player. They got into the input of your TV that has the RED/GREEN/BLUE RCA connectors. These are your video connector. Now, you need to connect the audio. Look for the RED/WHITE analog audio connectors out of your DVD player. Connector those to your AUDIO RED/WHITE input of the TV. Power on the DVD player and then power on your TV. Press the SOURCE or INPUT button on the remote for the TV until you see the DVD on the TV....The second option is the connect your DVD player up to your TV with composite video, YELLOW/RED/WHITE cable...
May 16, 2009 | Sanyo DP32648 32 in. LCD TV
DVD player wont work with TV
First, make sure that the units are connected properly * I know it's obvious, but I did it myself one day * Then on your T.V. remote, try hitting INPUT and it should run on your VIDEO channel.
This will work 99.99% of the time. Let me know,
Please rate me.
Jan 07, 2009 | Memorex MVD2042 DVD Player
Trying to hook up dvd player with sanyo tv. Also hook this up to satellite and surround sound. No picture, just audio.
Well are you ready for this I hope you can under stand if not maybe I can draw a diagram. Starting with your stereo take the component video out and goto component on the back of your tv to component in then the stereo coaxial in to the digatl audio out on the DVD player then DVD player anntena out to TV anntena in then DVD anntena in to reciever anntena out and Sat cable to reciever. also s-video on Dvd componet to s-video on TV DVD player Audio out to Audio in on TV. Set Stereo to TV and DVD player to channal 3 or do auto scan and TV will work on 3 with the reciever and also TV works with Video 2 I hope this works for you good luck
Jan 03, 2008 | Sanyo DS31590 31" TV
Durabrand DWT1304 13" TV Logo
1,324 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
