Question about Pentax Optio 60 Digital Camera
Pentax Optio 60 LENS
I get a LENS ERROR when I turn camera on, and then it shuts down. The camera is just past warranty, damn it.
  • 11 more comments
  • kminchew4 Dec 19, 2007
    brand new batteries camera truns on and off right away.
  • cas43952 Dec 26, 2007
    When I turn on my camera it says lens error then shuts down
  • Anonymous Jan 10, 2008
    when camera turned on, lens error message and camera shuts down. nothing works....batteries fully charged.
  • sessalulu Feb 02, 2008
    daughter's optio 60 also has the same problem - any hints?
  • Anonymous Mar 24, 2008
    When I turn the camera on I get the error " Lenses error
    " then it shuts off, any body have any hints on how to fix problem
  • Anonymous Mar 25, 2008
    turn cam on ...LENS ERROR... seems to be a very common problem !
    why no answer or fix ...other than buy a new camera, bud?
    perhaps we should all buy a different brand,bud!!!
  • Anonymous Apr 16, 2008
    When I switch on the camera says Lens error and switches off.
  • knokmeout May 26, 2008
    lens error when cut on, then turns off. Help.
  • maureenmg Jun 26, 2008
    lens error appears when i switch on
  • nancyyaya Jun 27, 2008
    I turn on the Pentax Optio 60 with good batteries in it and it comes up "lens error" then shuts down. I see there are several with this problem why doesn't Pentax recall this camera and either fix the problem or send us a new one???? I have purchased a new Cannon camera now and I would not ever buy a Pentax again.
  • lipscandotrx Jul 19, 2008
    As with the other customers purchasing the Pentax Optio 60- even with new batteries- my camera reads "lens error" and shuts off. Any solution? It's pretty damn disgusting since I can't use it.....
  • nakray2002 Aug 03, 2008
  • amankowich Apr 30, 2009
    Exact same problem, I posted it but have no replies.  Haven't even taken 50 pics yet.
The same thing happened with my camera, I gave it to a freind for her husband to look at it. He said when turning on face the lens side down (to the ground) when turning off hold lens side up right (to the sky). this worked for mine. I don't know if he did anything else to it but when I zoomed I got lens error. I did what he said and it took several tries but it did work... please post if this helps you.
Posted on Mar 06, 2008
When I turn my camera on it says lens error and shuts off. no damage to camera and new batteries did not help.
Posted on Dec 28, 2007
When turning camera on it is blinking and saying lens error will shut down automatically restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Mar 27, 2011 | Canon PowerShot SD1300 IS IXUS 105...
When i turn it on.. it says "lens error,will shut
Your camera almost certainly has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Canon service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera, or at least are able to use the information to help decide whether to buy another camera. If you do decide that you have to throw your camera away then don't forget to remove the memory card as it can be used in other devices. Please take a moment to rate the speedy and free answer I have provided for you and any testimonial which you might wish to add is always welcome.
Mar 07, 2011 | Canon IXY 1000 Digital Camera
My camera wont turn on it beeps 3 times. its stuck a bit open. it went like this from taking pictures it was not dropped and its past its warranty date.
Nov 22, 2010 | Polaroid i733LP Digital Camera
Lens error
May 28, 2010 | Canon Powershot A1000IS Digital Camera
Error lens
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Sep 20, 2009 | Sanyo Vpc-s1070w Digital Camera
Camera turns on and then shuts down leaving the
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jul 13, 2009 | Sanyo Vpc-s1070w Digital Camera
When I turn the camera on it shows lens error and shuts off
Jun 27, 2009 | Canon PowerShot A550 Digital Camera
Lens Error: 0x12110000 when previewing pictures in camera.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 01, 2009 | Sanyo Vpc-s1070w Digital Camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 22, 2009 | Sanyo Vpc-s1070w Digital Camera
Says lens error restart camera
Jan 06, 2009 | Canon PowerShot A590 IS Digital Camera
Pentax Optio 60 Digital Camera Logo
350 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
