Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Removing the filter on Dyson DC07
How do you remove the filter to clean
    Problem Solver:
  • 7 Answers
On the 07 model it is on the right side push clip and pull inside will be a foam filter wash and dry
Posted on Dec 04, 2008
  • 107 Answers
The filter is on the right side held in by a small tab.
Posted on Dec 09, 2008
    Problem Solver:
  • 4 Answers
The hepa filter is on the side at the bottom of the machine, inside the plastic housing. Pull the lever up and the plastic bit comes out and the filter is inside it. Have you got the instruction manual that came with the Dyson. It will be in there.
Posted on Dec 19, 2007
5 Suggested Answers
Dysonteam
  • 167 Answers
SOURCE: removing filteron dyson dc07 if stuck
Hi its Darran at Dyson.
We would recommend trying to twist the filter in the casing until it becomes loose. Sometimes, there can be a small build up of dust around the edge of the filter which can make it difficult to remove from the casing.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 19, 2010
SOURCE: Dyson DC07
http://www.analogstereo.com/dyson_vacuum_owners_manual.htm
Posted on Mar 19, 2008
SOURCE: How do I remove the washable filter to clean it on my Dyson bagless vacuum?
As you are looking down at the base of the machine (viewing from the front) you will notice a yellow button on the right side just inside of the the wheel area. push up the button to release the casing that holds the hepa filter and the spongy filter. You can see a diagram on your machine which shows this process. After you take the casing from the machine, the round housing which houses the 2 filters will come out of this casing as you pull it off. You can grab the spongy filter and pull it our of the casing. Rinse both filters as shown in diagrams on the side of the casing. Do not use soapy water, just warm water and squeeze out the spongy filter after each new soaking. Let the filters dry for 12 hours and then replace in your unit and enjoy the refurbished air movement. It does suggest that you clean these filters every 6 months.
Posted on Aug 09, 2008
  • 53 Answers
SOURCE: Dyson DC07 main filter can it be removed to clean?...
Yes, remove the dust bin and set it aside. Using a small screw driver gently pry on the lid that the dust bin sits on. you'll see little holes to insert a screw driver and pry back on the lid. Start on one side and pry at the three points to insert a screw driver and then remove the lid and replace the HEPA filter with a new one from EBay, local vacuum store, Dyson direct, etc. That filter is not washable.
Posted on May 31, 2010
Dyson DC07, is it possible to clean inside the circular sleeve (the one with holes) that is accessible when the shroud is removed to facilitate emptying,
I remove the complete cyclone/bin and hose it down with high hose pressure in all holes until you see no more dirt. Do not do this to the vacuum cleaner! Then dry it for a couple of days making sure it is completely dry before use. This gets rid of pet odour. Replace the post motor filter if this needs doing as it will be blocked.
Keith from Dyson Repairs North Shore Auckland
Sep 24, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do you clean the brush roller on a dyson vacuum
For a step-by-step guide on cleaning your DC07's brushbar, please visit our Support page::
http://www.dyson.co.uk/support/dc07/dc07-all-floors/maintaining-your-dyson-machine/how-to-remove-a-blockage/soleplate-removal
I hope this helps. If you have any further questions on using or maintaining your machine, please visit www.dyson.com and click 'Support', or give our Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 14, 2012 | Dyson DC07 All Floors Bagless Upright...
How do you clean beater bars dc07 animal
To clean the brushbar of your DC07 Animal, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc07/dc07-animal/maintaining-your-dyson-machine/how-to-remove-a-blockage/soleplate-removal
I hope this helps - if you'd like any further assistance or advice, please call our Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Mar 24, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
How do you get at filter to clean it/
The video embedded below shows the correct way to remove, wash and replace your DC07's pre-motor filter. Under normal use, this should be done every 3-6 months. Use cold water, and make sure the filter is totally dry before replacing it - this may take up to 24 hours.
The post-motor filter is a lifetime filter, and should not require attention. Do not attempt to remove or wash this filter.
If you have any further questions about using or maintaining your Dyson cleaner, it's probably best if you get in touch with us directly. One of our experts will be happy to provide the information and assistance you need. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Jun 24, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
May 20, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Removing filteron dyson dc07 if stuck
Kind regards
Darran
Apr 18, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do you remove the HEPA filter on Dyson DC07
I use a screw driver to pry them up.
Joe
Nov 07, 2009 | Dyson Vacuums
My dyson dc07 seems to take awhile to build proper suction... is this normal?
no it should pick up as soon as you turn it on, make sure the brush is turning if it is then turn the unit off, make sure the the washable filter is clean and the the bin filter is also clean, if this does not work then there one more thing if you can try, remove the bin from the unit release the bin flap and with a torch look down the end of the cyclone you might find a large blockage this vry common in the dc07 hope this helps
Oct 20, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Need owners manual
Hi, try here:
http://safemanuals.com/user-guide-instructions-owner-manual/DYSON/DC07-_E
I doubt you've ruined it, just clean/change it asap!!
Hope that helps.
Dec 07, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
787 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
