If the compressor is running - the suction pressure should be 65-75 psi - if it is very low - not enough freon - if it is very high - the compressor valves could be damaged - both will cause this
Testimonial: "the suction pressure is 65 psi and no cold air !!"
if your pressure is 65 psi and the unit does have r-22 - you need to check hi press side - should be 225 -270 - if this is low - compressor valve problem - if hi and low side is normal there could be some type of air flow problem - fan blades dirty/ coil dirty - if this is a heat pump - problem could be in reversing valve - only other thing i know of is the wrong freon type could have been put in unit - you would have to start over with freon charge and put in the correct amount as required on unit data plate
its R22
what are your pressurea and is it r22 or 410a?
