Question about Sony PlayStation Portable (PSP) Console
Psp laser not working
I just replaced my laser on my psp because it was not lighting up. I push down the little pin that makes everything work and the laser moves the disc drive spins but the laser is not lighting up. I checked my connections 3x and they are fine. my discs aren't being read at all....any help would be appreciated. thanks in advance.
  • Anonymous Mar 31, 2014
    only certain ps2 and movie discs will work but not every time. this is an 80gb fat ps3 with two lasers in the drive. if it still loads discs sometimes does that mean the drive still works or not I would appreciate any help thank you in advance
Sir or Madam ,
We are Xing Hui Electronics co,.ltd which are mainly specialize in the
production and wholesale of spare parts for playstation , and our products
include PS3, Xbox360, PSP&PSP 2000,PS2,WII Accessories. laser, modchip ,
memory card , controller, power board, battery charger, battery
bag ,console, LCD, PSP Laceplate, PSP GPS, PSP Camera,USB cable,
transducer ,as well as popular face plate ,and many kinds of electronic
parts, that with excellent quality and reasonable price. We welcome you
land our website: www.jiguangtou.com to check more details of us . as all
your inquiry will be replied in 24 hours . your kindly attention to us is
highly appreciated. Thanks
Posted on Jun 10, 2008
  • webma Jun 10, 2008
    Sir or Madam ,
    Problem Solver:
  • 17 Answers
Its a board problem have it checked.
Posted on Dec 15, 2007
My psp says that the disc is unreadable on multiple occassions for no apparent reason when the game works fine in my cousins psp
Sounds like there is a problem with the disk drive in your PSP. Open up the disk tray and look for the laser. Take a (very) damp q-tip and lightly clean the laser and gently push the laser center. If this does not work you will need to replace your PSP laser or send it in.
Jan 07, 2011 | Sony PSP (Piano Black)
Hey there i bright a psp and its not reading the games wat can cause that???
Hello
Switch on on your PSP and remove the UMD that might be inside
When you open up the UMD door and look down inside you will see the Laser assembly.
If you look to the left there is a black tab that sticks up, this tells the PSP that there is a UMD in the drive.
If you press this down with a small probe, you should see the disc motor spin and the laser light up red (do not stare directly at the laser)
Inspect to see If the Motor is spinning or not.is it moving slightly?
Take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser,check the cables to the PSP and see if there is a bad connection.
If both are running well then put a disc in and get your ear up close so you can hear what is going on in there.
On a working PSP you will hear the disc start to spin up, then you can hear the laser start to twitch, followed by the laser motor moving the laser down the rails.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be too much pressure for the disc to spin freely
Can you hear the Laser focus? This might be hard to hear it will sound like a little tick. If you cant hear it tick I would move on and inspect this internally later.
Can you hear the Laser move down the rail? This will be a smooth sound of the gears, it should not be a really clicky sound.
If you can't hear it move down the track OR it is very clicky do the fpllowing;
You should open the UMD door and carefully manually move the laser to the right side of the assembly.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing.
try and scrape the gears themselves to make sure there is no gunk or debris in the gear..
After this try and see if it is reading UMD again.
If none of this is working, it is time to open your PSP unit
If you are able to find out what's wrong from the troubleshooting steps above you can replace the problem by
Replacing the UMD, Assembly,Replacing UMD Disc Motor,Replacing UMD Laser Motor or by Replacing PSP Motherboard
Dec 15, 2010 | Sony Video Game Consoles & Games
My problem is my umd disc is not working in the psp.
I have seen many PSP's stop reading UMD discs and for the most part they are repairable with the least amount of opening your PSP.
First we will do some trouble shooting with what might be wrong with your PSP unit.
About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
Another 25% is the Disc Spinning motor. This will not let The disc in the UMD spin.
About 20% is the Laser motor, this might be hard to spot since it could be something in the gears.
About 10% is the actual laser itself. It will not focus the laser to read the UMD disc.
The Last 10% is the Motherboard. This is the worst outcome, since there is very little what we can do but replace the motherboard.
So first what we need to do is find out what is actually wrong with your PSP.
With your PSP in hand.
Turn on your PSP and remove any UMD that might be in there now.
If you open up the UMD door and look down inside you will see the Laser assembly.
*** CAUTION DO NOT STARE DIRECTLY AT THE LASER ***
If the Motor is not spinning. is it moving slightly? Maybe a little twitch?
I would lean more towards the bad motor problem BUT would not say for sure, I would recommend that you take the parts out and see if there is another problem also.
If the laser is not lighting up then it could be the laser, I would try and check the cables to the PSP and see if there is a bad connection.
If both are running well then lets put a disc in and get your ear up close so you can hear what is going on in there.
Can you hear the disc spin up? If not I would take the disc out again and press the switch with your probe again. if the disc motor is spinning again, look around to see if the metal housing is obstructing the disc when you put it in.. there could be to much pressure for the disc to spin freely.
If you can't hear it move down the track OR it is very clicky follow this.
It would look like this if your UMD door was off.
Use a sharp THIN probe to manually move the WHITE gear under the metal housing. It is quite hard to see it in the photos so I put a red star around it.
I usually try and scrape the gears themselves to make sure there is no gunk or debris in the gear.
This fixes it about 35% of the time.
If none of this is working, it is time to open your PSP unit Or send it in for repair.
If you know what's wrong you can replace the problem here
Replace UMD Assembly
Replace UMD Disc Motor
Replace UMD Laser Motor
Replace PSP Motherboard
Dec 03, 2010 | Sony PlayStation Portable (PSP) Console
My sony psp phat umd not read
If it's for all UMD's, you should check something out. Open up the UMD door and leave it open for this test. There's going to be a little lever inside that you need to push down. Looking at the UMD door from behind, screen facing away from you, the little lever is going to be on the top right, you'll see it. Push it down, while the PSP is on and look at where the laser is. You should see a red light coming from it, and it'll be obvious. If you don't see the light, your laser is broken.
May 06, 2010 | Sony PlayStation Portable (PSP) Console
My psp2006 ver5.03 cant read games
PSP UMD Repair: Not reading UMD discs
All photos and content copyright © Llamma Corp. 2002-2006
http://www.llamma.com/PSP/repair/PSP_UMD_Not_Reading_Discs.htm
Jul 16, 2009 | Sony Video Game Consoles & Games
EVERYTHING IS WORKING BESIDES THE GAMES WILL NOT
Make sure the UMD disk is clean and you have the latest firmware installed. If that doesn't work, open up the UMD slot and clean the laser with a lint-free cloth. If all fails, you will need to get your PSP fixed or buy a replacement laser.
Jul 15, 2009 | Sony PlayStation Portable (PSP) Console
My psp won't load umd's and all i hear is a scrathing sound
The UMD laser might be dirty or broken. Open up the UMD drive and give the laser a clean with a lint-free cloth. Then pop the disk back in and try again. If that doesn't work, you will need to get the PSP repaired or buy a replacement laser and do it yourself.
Jul 14, 2009 | Sony PlayStation Portable (PSP) Console
It won`t read my game
First we will do some trouble shooting with what might be wrong with your PSP unit. About 35% of the time I find that there is something stuck in the UMD gear. It is different every time, sometimes its a piece of dust, plastic, soda, and even hair.
if you need more infomation please just ask ... Symo02
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
HELP PSP WONT READ UMDS!!!!
hi i just fixed my sons it wasnt reading umd's every thing else worked so have a look were the threaded rod runs threw the laser, in the centre at the back of the laser there is a little tab with a stamped groove in it make sure the laser is up against the disk spinner when turned off push the tab against the threaded rod hopefully it has seated (you ned a good light plus i used long metal twesers to push it down, easier to see on 2000 model than the fat one but you can manage good luck)
Mar 09, 2008 | Sony PlayStation Portable (PSP) Console
Psp laser problem
I will advise you change the board and have it tricked to a custom firmware it saves stress on the lens unit
Dec 14, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
416 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
