Question about Relisys RLT1720 17" LCD Monitor
Horizontal lines lcd monitor
Is it common to have horizontal lines appear when booting to a LCD Monitor? I just bought it - Acer P241W. Never had a LCD before so am not sure if normal or defective?
I think monitor is defective. Contact manufature
Posted on Jan 10, 2008
What causes horizontal lines to appear at the bottom of my P224W monitor?
check for a loose vga port, if no loose connection at this time you are going to remove the cover of the monitor.check for a loose connection( ribbon wire) on the lcd controller going to the lcd panel.
Sep 27, 2012 | Acer P224W 22 inch LCD Monitor
Hey I got an IBM T42. It boots fine when its clear but after that it horizontal lines being to appear througout the scree.
Either you can hook up an external monitor or access BIOS setup (Basic Input/Output System) to replicate if the horizontal line appears. This step will check if the problem is with the video card or the LCD.
If you get the horizontal line on the BIOS or never get it on the external monitor, then surely the LCD screen is beginning to fail. You need to reinsert and/or replace the LCD inverter or LCD itself.
However, if you see the horizontal lines on the external monitor but not on the BIOS, try to update the video driver. If this will not resolve the issue, you need to replace the video card or the motherboard of your laptop.
Hope this helps.
Jun 06, 2011 | IBM ThinkPad T30 2366 Notebook
3 horizontal lines at top of lcd Acer AL1716.Can it fix. Is it lcd driver or mother board problem?
in order to diagnose whether the driver or the LCD you should try to plug your LCD into other Computer, if the line still appears then the problem is the LCD, you might have a dead pixel
Apr 23, 2011 | Acer AL1716 17" LCD Monitor
My Dell monitor developed a thin, dark line horizontally across the screen. Within three months, a second line appeared. I can view the screen, but must look above or below the lines at times. Any idea...
this occurs very commonly in all LCD monitors... this is because each and every cells in the LCD monitor are energized by the vertical and horizontal electric fields placed around the frame of the monitor... if a particular field does not gives the power to the associated cells to it, then the entire line of cells will not operate and together they looks like a single line...This is what happened in your case...
have a look at my tips for replacing the LCD screens on monitors, by clicking here....
Aug 11, 2010 | Dell Audio Players & Recorders
Horizontal line appears on my PC Acer screen and
There are two possibilities: That the monitor is bad, or that the video board is bad.
The easiest way to test is to install a different monitor and see if it does the same.
If it does the same, then it is the video board. If not, it is the monitor.
Sep 17, 2009 | Emprex LM2201 22" LCD Monitor
No monitor display
Return the monitor. I had one like that and I replaced it with a Dell.
Mar 23, 2009 | Acer AL2016W 20" LCD Monitor
Horizontal lines
i suggest you change video board .
Apr 19, 2008 | Samsung SyncMaster 152N 15" LCD Monitor
Acer P241W LCD Monitor
mine freezes in standby and I have to turn it off and then turn it on again each time
Jan 24, 2008 | Acer AL2016W 20" LCD Monitor
Acer 5100, Lines throughout screen!!
connect to an external monitor, if it works fine then it is the monitor, if not its the video card.
Dec 11, 2007 | Acer Aspire 5100 Notebook
Monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Nov 26, 2007 | Acer AL1711 17" Flat Panel LCD Monitor
Relisys RLT1720 17" LCD Monitor Logo
177 people viewed this question
Top Relisys Computers & Internet Experts
Marvin
Marvin
Paul
giarcnameloc
Level 1 Expert
Are you a Relisys Computer and Internet Expert? Answer questions, earn points and help others
