Question about Roper RAS8445KQ Top Load Washer
No cold cycle or spin
Washer will not run cold cyce ad will not spin but it will wash on hot or warm
    Scholar:
  • 196 Answers
First, check the temperature of the hot water and make sure it is hot and not warm. If the water is hot then the the problem could be in two areas. 1: water valve 2: Timer.
This machine will not spin if the lid switch is faulty.
Posted on Jan 12, 2008
Hot water fills for very short time on "Warm" setting - wash cycle is too cold
check either ur water temperature switch or and ur water inlet valve with a multi meter for continuity OHMS
Oct 16, 2014 | Amana NTW4650YQ 3.4 cu. ft. Top Load...
My Inglis washer machine (#111-07) which we bought 2 weeks ago, doesn't use any hot water when set to the warm cycle (in between cold and hot), so i can only wash with entirely cold or superhot water...
Hi Elllie602 (!) from retired Englishman in SW France,
2 weeks old? Under guarantee/warantee? Get in touch with the vendor/shop!!!
Even if it takes only cold water for the warm wash (which is a bit daft- normally washers mix the hot and cold accordingly) and heats it, that is not how most hot n' cold washers work.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 21, 2011 | Whirlpool Washing Machines
Cold fill washing machines
If your washer is the type that all rinses are in cold water only this would make sense that in the winter months when the water is at it's coldest the clothes will feel cold after the spin cycle.
If your washer has a warm rinse cycle and when you select the warm rinse option the clothes feel cold after the spin, then maybe the hot water supply line is plugged.I recommend disconnecting the hot water hose at the back of the washer and check the screen that is at the fill valve on the washer and make sure it isn't clogged with sediment or calcium build up or any other foreign material that would keep the hot water from entering the washer.If all is well there, suspect either the water temp selector switch or the hot water fill valve. Good luck !
Jan 23, 2010 | Washing Machines
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
Jul 12, 2008 | Admiral AW22 Top Load Washer
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Sep 07, 2007 | LG WFT1071TP Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
67 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
