Question about IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
Backup hard drive to an external hard drive
My external hard drive is 250 gigs and my laptop hard drive is about 30 gigs with about 5 gigs of free space..so what i was trying to do is backup the whole c drive to the external drive and delete some programs to give my computer more free space.... so when i tried to backup the internal hard drive it only backed up 4 gigs then said there was and error with something involving media so i repeated this process 2 more times and it did the same thing and stopped at exactly the same amount of data backed up. could there possibly be partitions on my external hard drive that i dont know about? and if so how could i fix it and if now how can i fix it...thanks for your time
  • aspec Dec 13, 2007
    what the error actually says is, you have either run out of space, or the backup file (.bkf) is too large for this disk. note: if the disk is formatted with FAT32, the maximum possible size for the backup file is limited to 4 gigs. The backup operation will stop.
    Problem Solver:
  • 8 Answers
As Pegleggedous said, the FAT32 File System only allows files that are 4GB or smaller.
Another solution to your problem is to convert your hard drive to NTFS.
Please note that you will only be able to use your hard drive with Windows 2000 & later if you convert your hard drive to NTFS. Instructions on how to convert your hard drive to NTFS are available on Microsoft's Website.
Have a nice day,
I/O Magic Technical Support
Posted on Sep 11, 2008
    Problem Solver:
  • 15 Answers
"what the error actually says is, you have either run out of space, or the backup file (.bkf) is too large for this disk. note: if the disk is formatted with FAT32, the maximum possible size for the backup file is limited to 4 gigs."
That error means that the FAT32 file system only allows 4GB files or smaller to be transfered. The chance that the backup file (.bkf) is larger than 4GB suggests that this file is causing your problems. You could try manually copying around that file (selecting all files from that folder except the large one) and see if that works.
Usually you will get many errors copying a drive directly as system files will be inaccessible and whatnot. Your best bet is to limit your copying to "C:\Program Files\" and "C:\Documents and Settings\", assuming you have Windows.
Posted on Jan 15, 2008
I backed up data w/ WD Passport External Hard Drive, and when finished my computer's free hard drive space went from 115 gigs to 11. What happened, and how can I fix this?
What could have happened is that you backed up your drive onto itself. Check your external and see if it's still empty. If you named the backup, search for that name and remove it. If not, retrace your steps right until the beginning of the backup and see what location the software stores the file then remove it.
Worst case scenario you can always use the windows restore utility and go back 1 day before you ran the backup.
Good Luck
Jul 17, 2010 | Western Digital Passport WDXML800UE...
WD 250 gig ext hard drive
Hello there:
you may want to unplug the device for 3 min and hold in the power button or the reset button for 30 seconds and than power the device back up and see if this helps If not go to control panel and click on system and look for the device manager and see if it is listed there if it is click on the device and where it says remove say yes than click yes again than shut down and restart the computer and the found new hardware will start up and reinstall the device again for you. ok? please keep me informed how this is going,
best regards mike
Aug 03, 2009 | Western Digital My Book Essential Edition...
Western digital passport essential harddrive 250 gig
It assumes that the drive C is the drive you booted from or the "root" drive. You must make it something other than "C". Try putting in a camera card, hooking up an external drive or other device that the computer makes drive "C" THEN hook up your passport. It will be "D" or "G" or something other than "C" and it will work.
Oct 24, 2008 | Western Digital Passport WDXML800UE...
WD portable 250 gb drive w/20 gigs of pictures
Is it truly broken or just not working, ie, not being recognized?
If it is broken, there are companies who specialize in data recovery.
One site is:
http://www.harddiskrecovery.net/
I've never used such a service, but they will give you a free quote.
Oct 14, 2008 | Western Digital 250GB MyBook External USB...
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
My HP laptop (1 gig memory) crashes when using Photoshop
crashes, as in locks up? What kind of video memory or card you have? And, how do you have it optimized(faster performance, most likely)? This takes a bit of 'tweaking' to get just right.
got backup for your HP?
Feb 13, 2008 | HP Pavilion zd7020US Notebook
Restoring backup files
well first off you should not use teh same external hard drive for both dell and mac! and for it to work on a dell you need to go to disc utility in the applications folder and click on you external hard drive and go to the last pannel which is called restore and put in the given info and it shall work!
Jan 04, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Moving files
just go to All programs<Accessories<System Tools<Backup. and choose the option you want.Once you have choosen what all you want to backup than you can choose the option for the place where you want to back it up.
Hope that works!
Dec 27, 2007 | Computers & Internet
Hard drive backup
Dear aspec,
First u try to perform scandisk the lap hdd. you also confirm wheather the bios is fully supproting the 250gb drive.
Tapa
(91-9830114059)
Dec 13, 2007 | IO Magic Corporation GigaBank (I250HD35)...
IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
196 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
Paras Waiba
Level 1 Expert
M_Butkus
Mohamed Ismail
Mohamed Ismail
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
