Question about Samsung LE32R41BD 32 in. HD-Ready LCD Television
Samsung LE32R7 Vertical lines problem
During normal viewing, be it through the aeriel, dtv or sky I can see faint vertical lines panning across the screen from right to left.
Normally, this is not noticeable, but it is most obvious during dark lite scenes when the panning vertical lines are most obvious.
Currently I don't have a DVD player attached.
Any thoughts on why this is happening?
Thanks in advance.
  • 1 more comment
  • manice Dec 29, 2007
    sounds like my problem. The answer??
  • Rainhill Mar 27, 2008
    Thanks for the suggestion but it already is plugged into a wall socket directly.
  • Anonymous Mar 29, 2014
    There is a dark line running vertically on the screen.
  • 29 Answers
Plug the TV into a wall socket by itself, have seen this when TV was plugged into a power strip.
Posted on Mar 15, 2008
Samsung TV display has gone out - has audio, but there are vertical, colored lines/bars across entire display.
Call a television engineer. Don't try and fix it yourself it always ends badly and more expensive. Could be a board, a component on a board, a bad connection, or blown capacitors. The course is 2 years full time education.
Apr 30, 2018 | Samsung Televison & Video
Vertical line on screen
Hi, This is a problem that's far too common among flat-panel and projection LCD TV's?and it's generally known as "vertical banding." If the lines are there all the time or intermittent but in the same location it is an indication of a bad panel. The panel driver can also be the cause of this symptom. Samsung panels have had issues with the connector that carries the LVDS signals to the panel itself, this is not serious and can be resolved and little cost. These faint vertical bars (often most apparent when the screen is totally dark or displaying a solid background, like the sky) are defects that occur during the manufacturing process, and while the worst offenders are typically screened out, many more make it to store shelves. Since you've pinpointed the banding and it's driving you nuts,also its under warranty, call the manufacturer and demand a replacement; in most cases, they'll capitulate and send you a new set, although you'll probably have to go to the trouble of packing and shipping back your defective TV (make sure the manufacturer covers your shipping costs). Regards sreejith
Jul 30, 2007 | Philips Magnavox 42MF521D/37 Television
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Panasonic ctp2780sf no picture faint line going vertical across screen
There are two reasons for this fault. A fault smoothing capacitor at the video output voltage rail, or excess of screen voltage. These lines are called 'vertical retrace lines' technically. Check this link for more details. It has a post, which have information regarding this fault. Go to older posts there.
Dec 25, 2012 | Panasonic Televison & Video
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
Oct 31, 2009 | Dell Inspiron 1720 Notebook
Faint vertical lines on my samsung lcd 1080
hi
this is the problem caused by 3 main issues
1.colour wheel
2.cathode ray tube
3.jungle ic on D-board
check it..//thank u
please rate it
Jul 04, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Faint Vertical lines on Samsung LCD TV
Your correct, LCD's don't burn. This sounds like a defective main control module. I would take it in as soon as possible to have it looked at.
May 03, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Apr 10, 2009 | Samsung ML 2010 Laser Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
56 V - faint horizontal lines across the display
u can search problem in vertical section may be sum IC component was dry resold them .
Aug 02, 2006 | SAMTRON 55V 15" CRT Monitor
Samsung LE32R41BD 32 in. HD-Ready LCD Television Logo
503 people viewed this question
Jerry Greenberg
Jerry Greenberg
