Question about GE WBSE3120B Top Load Washer
GE WJSE4150B1WW Model top load problem
My washer got stuck on the final spin cycle, i tried resetting, it did not worked,
i tried letting it run on final spin about 3 times, but just wont reset itself, please help me with this problem.
  • 3 more comments
  • Anonymous Jan 21, 2008
    I need help with my washer, it is doing th same thing. No matter where you turn the dial it lights up final spin.
  • ygershman Mar 17, 2009
    washer stuck on the final spin cycle,
    /* Style Definitions */
    {mso-style-name:"Table Normal";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    font-family:"Times New Roman";
    I hear the water @ the bottom of the washer.
    Please help,
  • Anonymous Mar 22, 2009
    I have the same problem. It spins and then turns off. There is no water visible in the barrel and the clothes are spun damp. But when I try to put a new load in, it is still stuck on "final rinse" and I can hear the water in the bottom.
  • Anonymous May 25, 2009
    exact same problem - any fixes?
  • garrettleery May 25, 2009
    same problem, any fixes?
  • 239 Answers
It sounds like the timer must have went bad or has a loose connection, If I understand you correctly its stuck in the spin mode. and won't go to rinse or wash cycle, Is that what you are saying, If so Maybe the start button got pushed in to hard or pulled out to hard. If It don't work let me know so we can work on something else so we can get it fixed for you, Happy Holidays bear001
Posted on Dec 14, 2007
Water in clothes after spin cycle
need to open washer and check the DRAIN MOTOR PUMP , usually gets clogged with lint and debris , usually located at the bottom side , small motor w/ propeller ,where the drain hose is connected, AJ
Nov 11, 2009 | GE WJRR4170E Top Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
How do you reset the washer?
I have a GE WBSR3000GWS Model and it stopped spinning at one point as well. My service guy came out and did the procedure below and reset it with in minutes.
How to Reset your GE Washer :
1. Turn the dial like your going to wash a load but do not pull the knob.
2. Unplug the washer from the wall and wait for 30 seconds.
3. Plug the washer back into the wall.
4. Lift the lid 5 times to at least 6 inches high. Open/Close within 15 secs.
5. Pause… You should here a click. If you do not, then repeat 1 – 5 again.
6. Insert a towel or garment into the washer and then pull knob to start the wash cycle.
7. Check the wash cycle to make sure the washer is agiating and spinning during its cycle.
GE Answer Center : 1-800-626-2000 opt 3 - for more information
Jun 20, 2008 | GE WBSR3140DW Top Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
GE Washer stuck on final spin cycle
Mine is also stuck on spin, but unplugging has not helped???
Apr 06, 2008 | GE WBSE3120B Top Load Washer
Washer stopped
Bear in mind I'M a novice.. but I'm going to try replacing the CONTROL PANEL ASM WJSE4150B1WW (for GE Model: WH42X10303 found one for $45 at ... I don't have the water temp problem but the other two yes...
Dec 04, 2007 | GE WBSE3120B Top Load Washer
Washer stuck on Final Spin
Sounds like a bad timer to test this you need a multimeter to check voltage to the advance motor if so equipped.
Oct 09, 2007 | GE WBSE3120B Top Load Washer
Top load washer won't stop spinning
make sure the timer is working you may have a bad spot in the timer and the timer motor stops in that place every cycle
Oct 28, 2006 | GE WWSE5200B Top Load Washer
GE WBSE3120B Top Load Washer Logo
655 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
