Question about Philips 32PW9308 32" TV
60PW9363 60" philips tv
At the bottom of the screen the line appear as mountain , the pic's appear dual vertically (altough the dualness reduces at the top of the screen ) and the colors are distorted too (more again at the bottom of the screen)
    Genius:
  • 1,694 Answers
Convergence issue = IC's need to be replaced.....
If you are doing this repair yourself = remove back...locate
large heatsinks with STK392-110 or 120 IC's..let me know.T.
Posted on Dec 13, 2007
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
I have philips 42' plasma flat tv one white vertical line appear hardly one mm on screen after a month two more line appear in the center of the screen and more two more line appear in screen
Line, faults & possible causes are given with illustrations. You can get an idea about the fault to an extent.
Sep 11, 2014 | Philips 42PF9630A 42 in. Plasma Television
Vertical lines running across
If this is a plasma TV then this is a popular complaint, usually caused by a loose or dead connection on the ribbon connectors, it could be a matter of just re-seating the connecter at the top/bottom of the vertical lines but BEWARE this involves taking the unit apart and more accidental damage may be caused.
Mar 06, 2011 | Televison & Video
Black blob on bottom rh of screen,vertical & horizontal lines
The blob is a phisically damaged part of the LCD screen. Unfixable, the screen must be replaced and it will be expensive.
May 04, 2010 | Lenovo 3000 N200 Intel Pentium Dual Core...
No video but sound works. white line across center
easy way is 4 wires will come from yoke coil(around pic/tube) green &yellow wires commonly used for verical deflection ..will be connected to soket. trace tracks from that connector points..on bootomside of pcboard..that tracks will lead you to vertical ic..commonly standing type ic..replace ic..check supply25v for the ic will come from l,o,transformer via a resister..good luck...
Mar 16, 2010 | Televison & Video
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Vertical lines in screen
grab your screen in the middle at the top,and flex it lightly,,kind of a twist ,does the screen change or the lines apear and move around,if it does check display ribbon at hinge for damage,and connection to graphics card,run dual display in clone mode with external monitor or tv,are the lines on it too?if they are .try reinstalling your graphics driver,and software,
Oct 06, 2009 | Computers & Internet
Blue Vertical Line
It is sounding like when the laptop is turned on and heats up a bit, the line appears? Sounds like one of the panels is going bad or atleast has developed a problem. below are some tricks you can try to lessen the annoyance of the line. Dual-Scan STN displays are composed of 2 panels behind a single protective panel or screen. Because you are looking through the protective screen the display appears to be one large panel even though it is not. There is a physical separation line (gap) at the point where the two panels meet. When the computer is on and being viewed it is not unusual to see the visible separation line with the Dual-Scan STN displays. The line, actually the fine gap between the display panels, appears because the color and light pixels cannot run along the very outside edges of the panels. This line (gap) between the panels can be seen as a fine gray line and is most noticeable when viewing on a screen with a white or light background. Note the line may not be as noticeable when the screen is displaying certain colors or darker backgrounds. SUGGESTIONS: It is not possible to completely eliminate the line but there are some things you can try to reduce it's visibility. 1) Lower the display brightness/contrast. The brighter the backlight the more noticeable the line. 2) Use Wallpapers and Screen savers that use darker colors. 3) In the Control Panel/Display applet under appearance try different combinations of color schemes for your Window and Background choice Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Philips 32PW9308 32" TV Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
